Author Topic: Yet another pumps thread  (Read 233274 times)
Re: Yet another pumps thread
« Reply #270 on: June 01, 2013, 09:24:15 PM »
Nige that looks like a jet pump, it'll have PPO innards which will be OK for shifting veg/bio until the ejector bit softens and shears off.  Best avoided I'm afraid.
Thanks for that Tony.....I'll not bother with that one now.
« Reply #271 on: June 01, 2013, 09:26:48 PM »
You going to bid on the other MS, Nige?
I'm going to have a punt at the other one Mark linked to:
http://www.ebay.co.uk/itm/Water-Pump-And-Motor-Jex-M-a080-/300912564316?pt=LH_DefaultDomain_3&hash=item460fc9585c
....unless somebody knows of a good reason not to. ie suitability etc
I was referring to this one ... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=271214160549&ssPageName=ADME:B:SS:GB:1123#ht_177wt_1066
If not I may have a bash at that if the seller will pack for courier.  Still no bids with two days to go.
It's all yours bud. Good luck.
« Reply #273 on: June 02, 2013, 01:13:03 PM »
« Reply #274 on: June 03, 2013, 05:20:29 PM »
Looks like this might be woth a punt if you're in the Taunton area...
Description says bits are broken, but if it's cheap one or two bits must be salvagable.
http://www.ebay.co.uk/itm/Agricultural-Industrial-Electric-Diesel-Pump-Hose-and-Nozzle-/111088027396?ssPageName=ADME:B:SS:GB:1123
« Reply #275 on: June 03, 2013, 05:51:46 PM »
I use one of those pumps for 1u filtering into barrels - it's a vane pump.
And just like it, the plastic fan cover is missing - mine dissolved in bio splashes, and the leccy box on top is going the same way.
It doesn't overheat from just filling 25l drums a few at a time but I wouldn't want to run it continuously like that.
« Reply #276 on: June 06, 2013, 10:19:00 PM »
Here's a little magnetically coupled chemical pump - would pick it up for its 99p but I already have a couple!
http://www.ebay.co.uk/itm/261225842376
« Reply #277 on: June 06, 2013, 10:27:42 PM »
Do you think this would stand up to ASM ?
I have a cunning plan.
« Reply #278 on: June 06, 2013, 10:32:31 PM »
Chemically it should be fine but isn't ASM quite gloopy?
« Reply #279 on: June 06, 2013, 11:19:50 PM »
Good point, maybe a gear pump is more the ticket.
« Reply #280 on: June 06, 2013, 11:54:12 PM »
But then you have the metal on metal problem instead... unless you can buy nylon gear pumps?
« Reply #281 on: June 06, 2013, 11:57:16 PM »
Smart arse.
Well I know you can get diaphragm chemical dosing pumps, so maybe this is the way to go, but they are £££.
« Reply #282 on: June 07, 2013, 12:33:52 AM »
With the playing about I've been doing dosing with small amounts of ASM, I've been toying with the idea of a peristaltic pump.  Very low flow rate butwould that do what you want?
« Reply #283 on: June 07, 2013, 11:21:29 AM »
Possably, me and Alex have been throwing a few ideas about, you know what I'm talking about.
« Reply #284 on: June 07, 2013, 01:04:09 PM »
The Bio-Grail if I remember correctly.
Will you get it done before the BBB or can Alex finish it on his own?
