Author Topic: Yet another pumps thread  (Read 232601 times)
Re: Yet another pumps thread
« Reply #690 on: July 03, 2018, 12:13:52 PM »
Anyone near Maryport fancy a big gear pump?
https://www.ebay.co.uk/itm/Rietschle-pump-lube-oil-transfer-WPB-25-20/183263706637
Comes with motor end of the coupling, just needs replacement motor.
Don't see gear pumps that size on eBay very often.
6000 l/m … that would take just over a second to fill my processor … don't think my reactions are quick enough to hit the stop switch in time!
« Reply #691 on: July 03, 2018, 10:43:59 PM »
first data plate says 1.1kw... that's not enough to shift that much?
second data plate says 21 cubic meters per hour, about 350litres/min... but also says 9.55kw (maybe 8.55?)
« Reply #692 on: July 04, 2018, 01:34:14 PM »
It is a "lube pump" so possibly designed for high flow but low pressure?
I did wonder if the flow rating was a mistake, or there was supposed to be a decimal point in there somewhere.  The ports don't look anywhere big enough to pass 100 litres per second.
« Reply #693 on: February 25, 2019, 10:27:44 AM »
Decent Mono for £20 in Bury St Edmunds
https://www.ebay.co.uk/itm/202606681372
