Processor - Appleseed
One important point to note with the Appleseed processor is that it is based on a standard US water heater which is a pressurised vessel. The original design concept sealed the processor by closing a valve located on the vent line as a means of preventing escape of methanol vapour.
Current best practice avoids any possible pressurisation or vacuum of processors in favour of venting vapours to atmosphere in a safe manner. The diagram below shows the later design.
State diagram
Step 1. (Oil In)
Unless your processor pump is self priming, or you store your oil in an adjacent tank whose level is higher than your pump, you may have difficulty priming the pump to fill the reactor. An alternative method is to use a separate, self priming, pump such as a hand operated barrel pump.
Step 2. (Heat oil)
Step 3. (Add the methoxide)
When the dosing is complete, close valve V3. Be aware that methanol fumes my be emitted from the vent during the addition of methoxide.
Step 4. (The reaction stage)
Step 5. (Settle the glycerol)
Step 6. (Drain the glycerol)
Attach your glycerol collection container to valve V2. It is preferable that this container is sealed and has a vent to a safe area. If it hasn’t, take great care to perform this operation in a well ventilated space and not to inhale any vapours being displaced from the container.
Now open valve V2 slightly to allow a slow trickle of glycerol to run into the collection container. You can expect to collect up to 25% of the volume of the oil you used as glycerol, so you should ensure that you container is of sufficient volume.
You will see when all the glycerol has been drained, because the drained liquid will suddenly become much lighter in colour and runnier as the flow changes to biodiesel. Close valve V2 completely now and wait a couple of minutes. Re-open valve V2 very slightly and you should be able to drain off a little more glycerol. When no more glycerol flows, close valve V2 and remove and seal the glycerol collection container.
Step 7. (Drain the biodiesel)
Open valve V4 and start the pump. If pumping into an open topped vessel, do so in a well ventilated space and avoid breathing any fumes evolved. The biodiesel will still contain a percentage of methanol and as the temperature is close to the boiling point, methanol fumes will be evolved. Where possible it is preferable to decant into a closed and vented vessel.
Step 8. (Drain the sight tube)
Now the processor is empty the oil retained in the sight tube can be drained by placing a small container under valve V2 and opening valves V6 and V2. This oil can be returned to your oil storage.
