Water washing titrated acid method
Introduction to the method
Where a settling tank is employed, this method negates the onerous task of periodically removing soap deposits from the tank. With the titrated acid wash method, usually all that's found at the bottom of a settling tank is residual water and either sodium or potassium sulfate in the form of an intermediate "scum" layer. If a valved drain is fitted to the settling tank, these can be occasionally drained off without the tank ever needing to be drained.
The process steps
Producing the biodiesel
Converting the soaps
This converts the soap as follows. If using NaOH as a catalyst and sulfuric acid as a wash, sodium sulfate is produced. If using KOH with a sulfuric acid as a wash, potassium sulfate is produced. With hydrochloric acid as a wash, sodium chloride or potassium chloride are produced.
Water washing
Draining the wash water
This method usually produces a scum like substance at the water/biodiesel interface, probably sodium or potassium sulfate depending on the catalyst used. This scum is usually evident even if the bulk of the wash water is clear.
It should be drained to a point where wet biodiesel is running clear. This mix can be set aside to separate and good biodiesel drawn off the top and included in the next batch.
Drying the biodiesel
The fifth and final step is to dry the biodiesel. After drying, the biodiesel should be ready for use, but in practice it's preferable to let it settle in a tank for a week or so to allow any residual sodium or potassium sulfate to settle. Filtering through a fine filter will also assist removal if no settling tank is available.
The chemicals needed
Solvent for titrating
Titration fluid
Indicator solution
0.1% hydroxide solution
Acid
Phosphoric acid should not be used. It has been reported that this acid produces sodium phosphate which is a water soluble detergent and not conducive to the process.
Water
Example vinegar method
100 litre batch size
(11) Dry the wet bio diesel
