Processor - basic design
(Redirected from Two drum processing method)
Processor, centre. Wash tank, left. Settling drum, right. Source: KH
State diagram
Step Heater Pump V1 V2 V3 V4 V5 V6 Notes
Oil in Pre-filter oil. Ensure pump is primed.
Heat oil 70 -90°C Remove processor lid. Only heat to 60°C if glycerol washing.
Dry oil 70 -90°C Drain any settled water via V1 before starting pump. Disconnect V6 from methoxide container so venturi can draw air.
Cool oil Allow to stand until oil reaches reaction temperature of 64°C.
Add methoxide Replace reactor lid and ensure it seals completely.
Reaction stage React for about 1½ hrs or until 3/27 pass is achieved. If required 7% water wash can be carried out once the reaction is complete.
Settle glycerol Circa 1hr
Drain glycerol Crack open valve V3 and slowly drain glycerol.
Transfer for purification See separate state diagram for purification procedure
Step 1. (Oil in)
Your oil storage tank should be connected to the 'oil In' pipe. The oil in the storage tank should be above the level of the pump if your pump is not self-priming so the suction is flooded.
Step 2. (Heat oil)
Wet veg circulating - source: K.H
Hot pan test - wet oil - source: K.H
Hot pan test - dry oil - source: K.H
Heat to 70-90°C (you generally find what works best for you after a few batches) and leave to settle for a short period unless you intend to glycerol wash, see below. Once up to temperature you can switch everything off and after a short period, drain any water which has dropped out or carry on with the drying process.
Step 3. (Dry oil)
Remove the processor lid.
Step 4. (Cool oil)
Step 5. (Add methoxide)
With the heater off, valves V2 and V4 open, the pump running and your methoxide container connected to the suction of the venturi, open valve V5 to introduce the methoxide. This as quickly as your system will allow, unless you are using the pump suction, in which case please pay careful attention to the comments in the ‘basic design’ section. Close valve V5 once all the methoxide has been entrained.
Step 6. (Reaction stage)
Step 7. (Settle glycerol)
Step 8. (Drain glycerol)
Crack open valve V3 and allow the glycerol to drain slowly. If you try and drain too quickly you run the risk of creating a vortex in the processor and not achieving a clean split between the biodiesel and the glycerol. When you notice biodiesel draining, close valve V3. Wait a further 15-20 minutes and you should be able to bleed off a little more glycerol.
Oil drying diffuser. Source: KH
EmbedVideo received the bad id "Bv8ivoE7lXQ?fs=1&hl=en_GB" for the service "youtube".
Higher performance pump
Low oil level interlock
Non siphoning, in-line heater
See: In-line heater
Mixing eductor
Mixing eductor. Source: KH
Mixing eductor in operation. Source: KH
See: Mixing eductor
PID temperature controller
See: PID controller
