Hot pan test
Bubbles appearing during test.
Used by home biodiesel producers, the hot pan test indicates the water content of oils. All oils and fats used for cooking food will contain water to a lesser or greater extent. The hot pan test is not a quantitative test but gives a very good indication as to the oils suitability for making biodiesel or for use as a fuel.
How the test works
The theory is quite simple. Oil is poured onto a hot surface the temperature of which is well above 100°C. Any water in the oil will make it’s self obvious by boiling off.
Hot pan test - wet oil - source: K.H
Hot pan test - dry oil - source: K.H
Performing the test
  • Canola (rape seed) … 240°C
  • Corn … 232°C
  • Lard … 188°C
  • Palm … 235°C
  • Soybean … 232°C
  • Sunflower … 232°C
The figures above are for new oil. Each time the oil is used, the smoke point is irreversibly lowered by a small amount. The smoke point is usually well below the flash point of the oil so provided the smoke point is adhered to, there’s little chance of the oil igniting.
Once up to temperature, remove from the heat and pour in enough oil to cover the bottom of the pan to a depth of about 2 to 3mm. Closely observe the oil, one of three things is likely to happen.
  • Nothing – water content likely to be in the range of 0 to 500ppm and not significant for making biodiesel or using as a straight fuel. It may, however, be worth repeating the test just to ensure you had the pan hot enough!
  • Tiny bubbles are just visible with a soft crackling noise – the oil contains small amounts of suspended water. This indicates the oil contains about 500 to 1,000 ppm (0.05 to 0.1%) water.
  • Crackling noise accompanied by very obvious bubbling – the oil contains free water, very approximately 1,000 to 2,000 ppm (0.1 to 0.2%). Vigorous crackling indicates possible emulsification and somewhere in excess of 2,000 ppm (0.2%) water.
Alternative method
As an alternative to the above method, the oil can be put in a cold saucepan and brought up to heat whilst its behaviour is observed. The drawback with this method is the difficulty in knowing when the oil is over 100°C and hence when the test is complete. If you have a suitable thermometer or temperature measuring devise it will help, but be sure that bulb or sensor doesn’t touch the bottom of the pan or it will give a false reading.
If the oil reaches a temperature where it starts to smoke, remove from the heat immediately as it will be more than hot enough and the test will be complete.
It is preferable to use an electric ring rather than a gas flame to reduce the risk of the oil igniting.
WARNING
If the oil contains visible water don’t test it using this method. Besides being pointless because you already know it’s contaminated, it could be dangerous, spitting oil and causing burns.
