Pump - Tam 105
(Redirected from Tam 105)
TAM 105 centrifugal pump
TAM 105 specifications
  • Motor 230V 50Hz 1ph
  • Power 330Watts
  • Current 1.4Amps
  • Capacitor 8uF 450V
  • Speed 2800rpm
  • Max. Head 35M
  • Max. Lift (Suction) 7M
  • Bore Size 1”BSP
  • Max. Output 40L/min
  • Weight 7.2kg
  • Part No. 7230350
Components
  • Pump Body Cast Iron (Painted)
  • Impellor Case Cast Iron (Painted)
  • Impellor Case Seal NBR
  • Motor Shaft Seal NBR
  • Rotor / Gear / Impellor Brass
  • Shaft Key / Nut Stainless Steel
  • Motor Shaft Stainless
Performance
  • Voltage / Frequency 230v / 50Hz
  • kW 0.33
  • Amps 1.4
  • RPM 2800
  • Duty Cycle Continuous
  • Bypass Valve Y/N N
  • Max Flow 40 lpm @ 0 m head
  • Discharge Pressure 3.5 Bar / 50.75 PSI
  • Max Suction Lift (Dry) None
  • Max Suction Lift (Wet) 7 m
  • Inlet Fitting 1" BSP
  • Outlet Fitting 1" BSP
  • Max Particle Tolerance 100 Micron
  • Max Liquid Temp 90 Celcius
  • Max Room Temp 40 Celcius
  • Thermal Protection Y/N Y
  • Max Liquid Viscosity Water
  • Ingress Protection IP44
  • Fuse Rating - 5 Amps
Spares
ItemNo. Part No. Description ItemNo. Part No. Description
1 HT10501 Screw 15 HT10515 Capacitor
2 HT10502 Fill plug 16 HT10516 Terminal cover, 16-A Terminal Box
3 HT10503 O ring 17 - Not used
4 HT10504 Pump body 18 HT10518 Terminal block
5 HT10505 O ring 19 - Not used
6 HT10506 Impeller 20 HT10520 Stator
7 HT10507 Spring lock 21 HT10521 End cover
8 HT10508 Mechanical seal 22 HT10522 Fan cover
9 HT10509 Splash guard 23 - Not used
10 HT10510 Front cover 24 HT10524 Bearing 201
11 HT10511 Bearing 201 25 HT10525 Spring washer
12 HT10512 Key 26 HT10526 Fan
13 HT10513 Rotor 27 HT10527 Bolt
14 HT10514 Screw
Accessories
  • Foot Valve Filter 7950561
  • BSP Spigot Hose Connector 7950210
  • I.D. Reinforced Hose for Suction and delivery 7955010
  • I.D. Layflat Hose for delivery only 7955110
Maintenance
