Methoxide mixer
An important part of any biodiesel processor is the methoxide mixer. It needs to efficiently and most importantly, safely mix the methanol and catalyst so the catalyst is completely dissolved in the methanol.
  1. Safety, ensure that the mixer is air tight and vented safely.
  2. Materials compatibility, ensure all materials used are compatible with methanol, the catalyst used and the resulting methoxide mixture.
Methoxide mixer design 1
This design has two minor draw backs. It won't pick up every last drop of methoxide and due to the size of tubing employed it’s a little slow on delivering methoxide to the processor, about 1 litre/min with a good vacuum from the venturi. Neither is a major problem and both are far outweighed by its safety and ease of use.
Methoxide mixer design 2
Contributions needed.
Industrial mixer design 1
WarningIconSmall.png This section contains content relating to commercially available items or equipment.
This design is suitable for industrial installations where health and safety is a major concern.
