Effect of biodiesel on fuel injection systems
  • Delphi Diesel Systems
  • Stanadyne Automotive Corporation
  • Denso Corporation
  • Robert Bosch GmbH
Biodiesel and impurities
Fuel Characteristic Effect Failure Mode
Fatty acid methyl esters (general) Causes some elastomers including nitrile rubbers to soften, swell, or harden and crack Fuel leakage
Free methanol in FAME Corrodes aluminium & zinc
Low flash point
Corrosion of fuel injection equipment
FAME process chemicals Potassium and sodium compounds
Solid particles
Blocked Nozzles
Dissolved water in FAME Reversion of FAME to fatty acid Filter Plugging
Free water in mixtures Corrosion
Sustains bacteria
Increases the electrical conductivity of fuel
Sludging
Free glycerine Corrodes non ferrous metals
Soaks cellulose filters
Sediments on moving parts
Lacquering
Filter clogging
Injector Coking
Mono- & di-glyceride Similar to glycerine
Free fatty acid Provides an electrolyte and hastens the corrosion of zinc
Salts of organic acids
Organic compounds formed
Filter plugging
Sediments on parts
Higher modulus of elasticity Increases injection pressure Potential of reduced service life
High viscosity at low temperature Generates excessive heat locally in rotary distributor pumps
Higher stressed components
Pump seizures
Early life failures
Poor nozzle spray atomisation
Solid impurities Potential lubricity problems Reduced service life
Ageing products
Corrosive acids (formic & acetic) Corrodes all metallic parts
may form simple cell
Higher molecular organic acids Similar to fatty acid
Polymerisation products Deposits especially from fuel mixes Filter plugging
Lacquering formation in hot areas
Considerations for homebrew biodiesel
Note that this section is not part of the document above, but our take as biodiesel homebrewers.
Minimising free fatty acid and mono/diglyceride content
Removing methanol and glycerol
Avoiding polymerisation products
Red residue that sometimes drops out when mixing biodiesel with mineral oil - in this case petrol
Same red residue at the bottom of a car's tank baffle
Fuel storage and oxidisation
Fuel system and engine care
Nylon tubing makes a good substitute for fuel line
  • Injector leak-off return pipes rotting - these are relatively easy to replace on most vehicles - nylon air line makes a good biodiesel-proof replacement
  • Injection pump shaft seals leaking
    • for gear driven pumps this can mean leaking of fuel into the crankcase oil (look for increasing engine oil level) and contamination of the fuel with engine oil (look for black deposits when the fuel filter is changed).
    • for belt driven pumps, failure of this seal usually results in fuel leaking out onto the road, but also possible contact with belts - particularly serious if a cam belt is affected, as biodiesel will rapidly weaken it.
Engine rattling due to air ingress is also a sure sign of seal failure somewhere, though if you're lucky the leak won't be at pump but further back in the fuel system, such as the fuel filter or at tank fittings. A section of clear braided hose (commonly 8mm ID) greatly helps with locating the source of air ingress - put between the fuel filter and the pump and backlit with a torch, any air bubbles will be clearly visible.
Peugeot 406 in-tank strainer
Blocked in-tank strainer from a Mitsubishi Delica
Suitable strainer replacement for the engine bay
Other potential issues include a blocked in-tank coarse filter with soaps or polymerisation products. Some biodiesellers like to remove the in-tank filter and fit a coarse filter before the main filter in the engine bay, where it is more easily accessible for cleaning or replacement.
