Dry washing
Ecopure and hardwood drywash medium
Ion exchange resin
Hardwood
A simple hardwood filter; dripping the biodiesel through a plant pot filled with shavings. Source: e3msb
Typically, a 10 litre tower should have biodiesel pumped or gravity fed through it, bottom to top, at a rate of 3 litres per minute. If the fuel is well settled before filtering, remove the majority of soap, 10 litres of medium should be capable of filtering 1000 litres of biodiesel.
When a tower has been freshly repacked with shavings, at first the flow of biodiesel will be contaminated with sawdust and possibly a small amount of resin. So initially, prime the tower by recirculating a small amount of biodiesel until the flow runs clear (the tower trapping any sawdust that escaped). The first batch passed through the tower should be settled before use, in case there are any wood resins present (these will drop out).
Do not use softwood wood shavings as these will be rich in resins.
How to make a drywash tower
This is just one version of many dry wash towers.
My version:
Parts
  • 110ml pipe x 3mt £9.05
  • access cap socket tail £8.32 x 2
  • 22mm comp tank fittings £1.75 x 2
  • 54x22mm end feed reducer £3.22 x 2
  • end feed 90,22 mm £0.40 x 2
  • end feed 22mm equal tee £0.71
  • spring safety valve 1/2" bsp £1.32
  • Gate valve 22mm £2.86
  • about 12 " 22 mm copper pipe
  • 1 X tea strainer £3.00
I made a pre filter to take some oak shavings which prolongs the life of the tower. It catches most of the soaps and I can keep an eye on it with it being clear.
