Author Topic: Yet another pumps thread  (Read 220545 times)
Re: Yet another pumps thread
« Reply #645 on: December 11, 2016, 07:49:40 PM »
Sorry to deprive the depraved.
« Reply #646 on: January 10, 2017, 03:42:34 AM »
« Reply #647 on: January 10, 2017, 03:22:35 PM »
I'm gonna snipe on that shiny MS.  My bio filter pump is falling apart (and, being a vane pump, is bloomin' noisy).  Plus I don't have an MS yet so my collection is lacking :)
« Reply #648 on: January 10, 2017, 04:18:23 PM »
Sorry, like the idiot I am I muddled up the links!  I'm sure you found it but just in case this is the correct link ... http://www.ebay.co.uk/itm/Dresser-Mono-Pump-with-Brook-Crompton-Motor-240V-Single-Phase-Type-CMS241-H13F-/262798501851?hash=item3d3002e7db:g:kq4AAOSwA3dYclhA
Good luck with it, it looks like a nice pump, less to go wrong on an MS ... no coupling, the rotor is screwed directly to the motor shaft and the flange on the stator flexes to account for the eccentricity of the rotor.
Let us know how you get on.
« Reply #649 on: January 10, 2017, 08:03:11 PM »
Wont you then need to spend about £70 on a viton stator?
« Reply #650 on: January 10, 2017, 08:34:55 PM »
Not bothered with my Mono ML, which I've had since my early bio days and is still going strong.  Paid £24 for that pump. :)
Stators do turn up on eBay for around the £25 mark if you're patient... same with rotors.
« Reply #651 on: January 10, 2017, 09:35:42 PM »
I have a spare rotor for my mono ml somwhere, but no stator - and, of course, its the stators that die.  I cant see a rotor ever dying from the amount of veg / glyc etc that i pump.
Ive always been careful to flush through with veg after pumping glyc, but i had an air leak on the inlet a while back, and it was running for a while, and i think some of the magic smoke has escaped from the stator.  It still pumps fine, but is a pain to prime.
« Reply #652 on: January 11, 2017, 12:06:55 AM »
Do you think friction damaged it then rather than the glyc?
I must admit mine has only ever pumped veg or bio and not at any temperature.
« Reply #653 on: January 12, 2017, 05:08:25 PM »
Yes, certainly.
The air leak was in the suction hose prior to the mono - so it was running dry for some time.  Well, oiled, but i think that the friction heated the rubber - there was 'smoke' rising up the clear suction inlet pipe when i turned it off.
I dont think glyc has harmed it due to always flushing it with veg.  But im under the impression that it would if i left it in there, left bio in there (etc)
I know Julian (brtp) uses his on his reactor, but i think his has a viton stator.
« Reply #654 on: January 12, 2017, 10:59:02 PM »
I do and it does have a Viton stator, however I'd used it for some time previously with a Nitrile stator and it was always parked full of whatever it last pumped.  Due to the way it's piped up this can be oil, part reacted bio C/W all chemicals and glycerin.
The stator required replacing only because it was old and I ran it against a closed valve which has a tendency to shear off the flange on an MS.  The Nitrile although a little warn didn't show any noticeable signs of chemical attack.
I'd just run with a standard stator until the time you HAVE to replace it then make the decision if it's worth paying the extra for Viton.
« Reply #655 on: January 22, 2017, 02:43:26 PM »
No luck on that Mono MS, I was outbid by a couple of quid!
I did however pick up another one, slightly more modern build - but it has been dropped on one end and the cowling is missing.  I had a long chat with Dave at Anchor Pumps (professional pumpophile as it turns out) and he asked Mono, but apparently not a part they stock as a spare and none on the scrappers pumps he's got...
« Reply #656 on: January 22, 2017, 03:10:37 PM »
Do you mean the motor cowling?  If so it's a good candidate for 3D print.
If you mean the plastic cover/s on the pump, there's an stl file on the wiki.
« Reply #657 on: January 22, 2017, 06:12:35 PM »
Yeah fan cowling.  I saw your .stls on the wiki (turned up when I googled!)
I'm thinking that the fan cowling would be a useful addition - though not general purpose (obviously depends which pump motor is fitted to the MS).
« Reply #658 on: January 22, 2017, 07:33:25 PM »
Over the years Mono used many motor suppliers ... could try the motor manufacturer if it still has its rating plate.
I think our resident trumpet player (who seem to be using his mute recently ... hope all is OK?) printed a motor cowl.  It may be possible to take his and scale to suit.
« Reply #659 on: March 26, 2017, 09:28:08 PM »
Good deal for someone - I'd have snapped this up if I didn't have quite a few of them already :)
http://www.ebay.co.uk/itm/122406206768
