Author Topic: Yet another pumps thread  (Read 232845 times)
Re: Yet another pumps thread
« Reply #660 on: March 27, 2017, 07:20:22 PM »
£90 not a bit dear ?
« Reply #661 on: March 28, 2017, 12:10:04 PM »
Well, they're £350 new, and multistage with stainless impellers, so it's not unreasonable. They push a lot of pressure so great for venturis and educators - the only catch is that they are closed impeller so the oil being processed has to be filtered.  I think they're great, seem quite happy pumping oil at over 100C.
« Reply #662 on: March 28, 2017, 01:42:32 PM »
I appreciate that it's only 1/3 of the consumpion of a frankenpump (TAM 120) but it doesn't really compare. Over 1 1/2 hours processing the extra cost would be about 18pence.
The head on the 120 is 65 metres and with an unmodified 1/2" eductor mine pumps at 71psi. someone on VOD calculated the nozzle velocity at 28 metres/sec. It was a bit risky at that pressure so from Jims' advice I drilled it to 8.5mms, now it pumps at 31psi with oil and 28psi with bio.
There is a slight efficiency gain as the fluid kinetics heat the oil without the immersion.
« Reply #663 on: March 28, 2017, 10:47:44 PM »
Ah yes, granted on the leccy cost.  At the time I first got one of those pumps I was running on a 13A extension lead so immersion+pump amperage was a consideration.  Then we fitted underground SWA cabling and a 32A commando, which made a big difference.
Then I moved house - back to the 13A extension lead again until we sort the electrics out!
« Reply #664 on: March 28, 2017, 10:50:02 PM »
Can you wrap the lead round the processor for added heating?
« Reply #665 on: March 28, 2017, 11:53:56 PM »
It's chilly in the garage so I wrapped it around my legs.  Health and safety first, can't be having cold calf muscles!
« Reply #666 on: April 21, 2017, 07:57:41 PM »
I could look back over the thread, but is this one of the ones Tony gets excited about -
http://www.ebay.co.uk/itm/122455381120
(im not bidding by the way)
« Reply #667 on: April 21, 2017, 10:17:02 PM »
Yep they're the ones, it was previously listed at a higher price so it is tempting... but I've already got a good collection so won't be adding to it!
« Reply #668 on: June 08, 2017, 11:34:14 AM »
Does this have any BD or WVO application?
« Reply #669 on: June 10, 2017, 06:35:49 PM »
Bump!
« Reply #670 on: June 10, 2017, 06:47:07 PM »
Are the end fittings plastic or painted black steel?
Anything plastic isn't likely to last, of course - not sure how useful having two pump heads is either (trying to think of an application for that!)
« Reply #671 on: June 12, 2017, 11:20:08 AM »
The black ends are plastic.
I don't know what to do with it either. I saw it at a carboot sale for a fiver.
« Reply #672 on: June 12, 2017, 11:49:14 AM »
Do you need a power shower in your house?  8)
« Reply #673 on: June 12, 2017, 08:32:30 PM »
No.
« Reply #674 on: June 22, 2017, 02:51:45 PM »
It looks like ive spotted one before the usual suspects -
http://www.ebay.co.uk/itm/332275611367
£55 of possibly usable spare parts there.
