Author Topic: Yet another pumps thread  (Read 233274 times)
Re: Yet another pumps thread
« Reply #180 on: February 04, 2013, 11:18:23 PM »
How about 1 inch Bsp inlet with 22mm pipework onto it.
Mmmmmm! let's put it this way, I wouldn't do it, I'd run 28mm from the tank outlet to the pump with LONG radius bends, if needed.
« Reply #181 on: February 05, 2013, 04:42:14 PM »
LOL, so fancy building me a twin cone reactor with 22mm piping and pointing me to an 80 LPM pump with 1 inch Bsp inlet to go with it then Jim. Ya could have pointed it out all them years ago.
Anyways it's worked absolutely fine all the time I have had it. Empties the reactor in the time you would expect based on flow rate and even now has a 110 lpm pump which also works without issues.   So I assume theories don't always have the effect in practise maybe.
« Reply #182 on: February 05, 2013, 08:44:14 PM »
Woh, you've queezed 110lpm through a 22mm pipe?  The fluid velocity must be incredible.
Here's 80lpm through a 22mm pipe on my processor
http://www.youtube.com/watch?v=1v1w6chKYos
This is fine for discharge pipework in relatively short runs but definitely not for suction - the problem is getting cavitation when the Methanol/biodiesel mix is approaching the point where the Methanol is starting to boil - even the slightest resistance can cause cavitation and this dramatically affects the pump's performance and ability to drive the venturi.
Every pump's performance is different, and for the same maximum flow rate two pumps can have different inlet sizes, presumably a decision by the manufacturers based on anticipated suction run length.  There are some general rules on fluid velocity for pump inlets and outlets, they all vary depends on whose advice you follow, but they all allow roughly twice the outlet velocity than the inlet velocity.  I'll have to see if I can find my notes but I'm pretty sure 80lpm through 22mm is way over all of the recommended inlet velocities :)
Generally if you go by the inlet size to determine the pipework sizing there's not much to get wrong.
« Reply #183 on: February 05, 2013, 09:09:15 PM »
If you hadn't use the elbow on the 22mm pipe you'd have seen some real flow.
Strangely enough Stuart Turners use 3/4" in and out on their 80/90ltr pumps wheres as the TAM has 1" on their 40ltr pumps
Offline jgs600
    • www.biopumps.co.uk
« Reply #185 on: February 22, 2013, 01:29:32 PM »
this is a video of one of my 110lpm pumps in action roughly fitted to 3/4  22mm pipe work
http://youtu.be/RPbyO22qYhs
1998 c250 merc..100% bio
« Reply #186 on: February 22, 2013, 01:46:51 PM »
If you want excellent service and after sales backup you will not go far wrong with one of Glenn's pumps.
« Reply #187 on: February 22, 2013, 01:56:11 PM »
I've seen worse than that on an auction site being sold as a proccessor!   ;)
« Last Edit: February 22, 2013, 01:58:41 PM by Keef »
Offline jgs600
« Reply #188 on: February 22, 2013, 02:24:48 PM »
i agree there are some shocking processors on eblag thats for sure...
« Reply #189 on: February 25, 2013, 01:39:59 PM »
« Reply #190 on: February 25, 2013, 01:48:31 PM »
That's going some :)
BTW you should spell check your site - capitalise I's, vegetable is miss-spelt in one place and replace wont with won't and cant with can't.
« Reply #191 on: February 25, 2013, 02:49:50 PM »
You may want to check the spec's on the pumps too, the figures look a bit ambiguous.
« Last Edit: February 25, 2013, 09:51:00 PM by 1958steveflying »
« Reply #192 on: February 25, 2013, 09:32:05 PM »
« Reply #193 on: March 11, 2013, 01:56:25 PM »
150lpm Lowara CAM120/55/A-V, 99p start Manningtree, Essex
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=261183469907
Offline jgs600
« Reply #194 on: March 11, 2013, 02:14:45 PM »
dont need it but i just put a bid in for a tenner, made the buy now for £400 go away  :)
