Author Topic: Yet another pumps thread  (Read 233274 times)
Re: Yet another pumps thread
« Reply #165 on: January 28, 2013, 12:00:58 AM »
This is my Pedrollo, stripped for some pics, its still going on my first processor that i sold to a friend
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=11595
I don't believe that for one minute!
Don't believe what, that it's his pump or that he has/had a friend?
The nearest he'll ever get to friend is his Teddy Bear.
That he's got a friend.
I heard his Teddy Bear checked itself into the nearest charity shop.
« Reply #166 on: January 28, 2013, 08:10:07 AM »
I think due to design, centrifugal pumps will suffer with hot meth laden bio,
they produce low pressure in the center of the impeller, this low pressure will promote cavitation and reduce flow rates.
Cavitation is when due to a combination of heat and low pressure the liquid turns to a gas.
It might come down to impeller design - the Pedrollo ones are only very basic - by comparison the Calpeda multistager has gently rounded intake shapes which sharpen towards the outside of the impeller, and didn't seem to suffer the same flow rate limitation with hot bio.  On the other hand you could argue this shears the liquid less so perhaps not as good for mixing?
« Reply #167 on: January 28, 2013, 08:16:10 AM »
Just because no one else can see my friends doesn't mean they don't exist!
« Reply #168 on: January 28, 2013, 07:46:37 PM »
So which one of you and your invisible friends is Napoleon?
« Reply #169 on: January 28, 2013, 09:54:13 PM »
The one that's not Spartacus!
« Reply #170 on: January 28, 2013, 10:07:00 PM »
Im sure my shrink said i have been both of those in previous lives and anyway Soap Rich Bio Poor rather a Teddy than your Sindy
« Reply #171 on: January 28, 2013, 11:00:57 PM »
As of today I'm down to a mere 80 ltrs of soap and don't let my life size inflatable Barbie hear you mention Sindy.
« Reply #172 on: February 04, 2013, 11:11:42 AM »
Little pump down Devon way, might be good for drywash or slow circulation?
http://www.ebay.co.uk/itm/240v-Pump-Ideal-For-Water-Petrol-Desel-Kerosene-Heating-Oil-Etc-/140911586659
« Reply #173 on: February 04, 2013, 11:23:24 AM »
« Reply #174 on: February 04, 2013, 11:31:42 AM »
300lpm Stainless Lowara @ £50 in Kent (Single Phase)
http://www.ebay.co.uk/itm/Lowara-CEAM-210-3-V-CENTRIFUGAL-PUMP-STAINLESS-240V-/300856377473
That'd do someone nicely for a processor!
Actually the 300lpm is rated at 14.4m head so on a processor with only a couple of meters head it might well do better than that.
« Last Edit: February 04, 2013, 11:36:27 AM by Tony »
« Reply #175 on: February 04, 2013, 06:48:09 PM »
Think I may have a go at that one in Kent.
« Reply #176 on: February 04, 2013, 07:36:25 PM »
A pump head, as marked on the plate, is a measure of Dynamic head, you're not allowing for the static head on our plants.
The dynamic head we deal with is measured in inches, it's the height between the surface of the oil to the return pipe.
Basically we only have to worry about pipe resistance not head.
« Reply #177 on: February 04, 2013, 07:43:41 PM »
Ah yes, good point.  Even better then.
Anyone that bids needs to remember that  they will have to install suitably large pipework to get the most from the pump.
« Reply #178 on: February 04, 2013, 07:51:08 PM »
Very true, NEVER fit less than the pump size on the inlet side and NEVER drop more than one size on the outlet.
« Reply #179 on: February 04, 2013, 10:14:43 PM »
How about 1 inch Bsp inlet with 22mm pipework onto it.
