Author Topic: 12v pump or, Ged and his pump journey ::)  (Read 44500 times)
Re: 12v pump
« Reply #45 on: January 12, 2015, 08:30:10 AM »
If you connect a centrifugal pump's discharge to the inlet with appropriate valves, you can persuade them to self prime. Although you need a bit of fluid in it to begin with.
I do this with a TAM105 and while it can take a little while to get it going, it's reliable at priming.
Re: 12v pump
« Reply #46 on: January 12, 2015, 09:32:18 AM »
Get a Lutz pump, designed for emptying drums, self priming, ive used mine for emptying IBC,s
Dickjotec has one as well if you want a second opinion :)
I think dickjotec may have 2x now :)
Re: 12v pump
« Reply #47 on: January 12, 2015, 09:40:10 AM »
my car cost me less :-[
Re: 12v pump
« Reply #48 on: January 12, 2015, 09:51:26 AM »
my car was £180 :)
Re: 12v pump
« Reply #49 on: January 12, 2015, 01:32:26 PM »
vendor offered a replacement or refund. no hassles and very nice to deal with.
as i have lost time and confidence in the pump, i opted for the refund.
whilst the macerator looks good, i need something tried and tested.
either
http://www.ebay.co.uk/itm/261724500910?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
or
http://www.ebay.co.uk/itm/301405183156?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
or
http://www.ebay.co.uk/itm/281234891831?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: 12v pump
« Reply #50 on: January 12, 2015, 04:05:36 PM »
won this at £69:89 plus £15 thats £85
same as the refund.
http://www.ebay.co.uk/itm/261724500910?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT&autorefresh=true
just spoke to Hytek, the RRP on that pump is £280.
Re: 12v pump
« Reply #51 on: January 12, 2015, 06:03:11 PM »
V nice  :)
Re: 12v pump
« Reply #52 on: January 12, 2015, 09:58:19 PM »
looks like the pump breaking ended up doing you a favour and getting a decent pump for the same money, result!
Re: 12v pump
« Reply #53 on: January 12, 2015, 10:50:11 PM »
hope so.
i had problems with my diaphragm pump on the car too.
after three years of constant use it started leaking, so i ordered one from a uk seller at about £10 over chinese rates as i needed it there and then.
in winter, it stops the fuel vaporizing in the FPHE, and moves any bubbles that do form back to the tank asap.
i specifically ordered one with hose tails on, but the vendor sent the wrong connections on.
when i contacted him he refunded it and said to just chuck the other one in the bin.
took me an hour to click that it was exactly the same as my old one internally.....
im sick of pumps.
Re: 12v pump
« Reply #54 on: January 14, 2015, 01:11:59 PM »
the pump still had the original packaging
along with the original shipping label.
Re: 12v pump
« Reply #55 on: January 14, 2015, 02:11:56 PM »
i fucking give up.
now my 12v supply has died.
anyone want a brand new pump?
Re: 12v pump
« Reply #56 on: January 14, 2015, 03:01:09 PM »
right, supply burnt out, pump ok,
if anyone wants a complete hytek filling set up, comprising pump, filler, nozzles everything, let me know.
im giving up.
Re: 12v pump
« Reply #57 on: January 14, 2015, 05:45:53 PM »
Computer PSUs are cheap to come by and will deliver enough juice to drive it.
Re: 12v pump
« Reply #58 on: January 14, 2015, 08:00:50 PM »
Ged, have a look at RM's scrapyard thread ... small Mono MS.  Not a massive through put, but if it's working it'll be far better than any of the others you've tried.
Re: 12v pump
« Reply #59 on: February 02, 2015, 06:31:38 PM »
