Author Topic: 12v pump or, Ged and his pump journey ::)  (Read 43762 times)
« on: December 08, 2014, 10:20:22 PM »
« Last Edit: February 06, 2015, 12:51:34 PM by GedsJeep »
Re: 12v pump
« Reply #1 on: December 08, 2014, 10:24:22 PM »
This would be my first port of call:
customerservice@deuba.info
Re: 12v pump
« Reply #2 on: December 09, 2014, 12:20:57 AM »
that was mine too.
still waiting with nearly a tonne to move around.
 :o :o
Re: 12v pump
« Reply #3 on: December 09, 2014, 02:42:02 PM »
replied that no spares are available.
fuck.
Re: 12v pump
« Reply #4 on: December 09, 2014, 02:55:16 PM »
Brushes are usually quite simple things.
In the past I've taken brushes from a dead motor, filed the carbon, modified the spring or used a separate spring and fitted to another motor.  I have a few oddballs kicking about somewhere ... what are they like?
Post a photo and dimensions and I'll see if I have any that might be suitable.
Re: 12v pump
« Reply #5 on: December 09, 2014, 03:39:36 PM »
^^This
Done it a few times now to get out of scrapes.
Re: 12v pump
« Reply #6 on: December 09, 2014, 04:49:08 PM »
cheers julian.
in the spirit of that comment i had the same thought this morning. so i looked on eblag and came to the conclusion that any brush with the wire in the top centre would do as long as it is of roughly the same dimensions.
will strip it tonight and have a wee measure.
Re: 12v pump
« Reply #7 on: December 09, 2014, 07:12:29 PM »
I've used the carbon out of a carpenter's pencil. Super glued them together with wire between them then filed down to size. Did it on my jigsaw 18 months again and its still going strong.
« Last Edit: December 09, 2014, 07:14:59 PM by willbuild »
Re: 12v pump
« Reply #8 on: December 09, 2014, 09:15:23 PM »
these are a bit bigger.
7mm wide
8mm tall
16 mm long.
wire top center.
Re: 12v pump
« Reply #9 on: December 09, 2014, 09:16:29 PM »
and where can i get the wire thats in them?
i do have a u/s b&q jet pump. would that have some in?
Re: 12v pump
« Reply #10 on: December 09, 2014, 09:39:03 PM »
Re: 12v pump
« Reply #11 on: December 09, 2014, 09:40:37 PM »
De soldering brade works well and solders easily just do not apply to much solder as it wicks down
fast.
Re: 12v pump
« Reply #12 on: December 09, 2014, 11:47:14 PM »
Re: 12v pump
« Reply #13 on: December 10, 2014, 12:27:55 AM »
thats what im hoping for. the pump still works fine, but you have to belt it to free whats left of the brushes.
and i still have 300L stuck in the front garden and a full shed....
Re: 12v pump
« Reply #14 on: January 01, 2015, 10:26:09 PM »
right, the brushes worked.
now the effing motor has burnt out.
there was a decent version of that doing the rounds, anyone got as link to it?
i would prefer 12v, but ive just seen this,
http://www.ebay.co.uk/itm/BIO-DIESEL-60-lpm-OIL-PUMP-free-P-P-/191464813148?pt=LH_DefaultDomain_3&hash=item2c9431325c
any experience?
