Author Topic: 12v pump or, Ged and his pump journey ::)  (Read 44476 times)
Re: 12v pump or, Ged and his pump journey ::)
« Reply #75 on: February 10, 2015, 05:00:21 PM »
with julians help  ;)
« Reply #76 on: February 10, 2015, 05:16:50 PM »
That's certainly a new pump from the state of the rotor and stator ... absolute bargain.
I did say that they don't have a high capacity, however,  if it's a major issue, keep an eye open for an MM or ML.
One thing I forgot to mention ... don't run it against a closed valve. If I remember a conversation with Mono correctly, if an MS is dead headed, it can tear the flange off the rotor.
« Reply #77 on: February 10, 2015, 05:27:54 PM »
nah, i can live with the throughput.
i cant see a situation where i would need 60L of oil three mins quicker ;)
im well chuffed.
thanks julian.
« Reply #78 on: February 10, 2015, 05:31:49 PM »
I didn't do much other than persuade you to buy it, but I'm glad you're pleased with it.
« Reply #79 on: February 16, 2015, 05:50:57 PM »
ok, verdict after a week or so.
excellent.
had a spring clean in the shed today and emptied all my pre filter drums.
pumped 800L of jelly like slop into 60`s ready for sale tomorrow.
never slowed down or missed a beat. some of it was really disgusting and it just ate it up.
need to mount it somewhere with nice long hoses coz its a heavy bugger to move about.
would seriously recommend one
« Reply #80 on: October 02, 2015, 02:53:04 PM »
and......
back to square one.
the 12v pump i bought packed up.
the mono now will not self prime and wont clear the air....
im gonna buy a tam copy.
« Reply #81 on: October 02, 2015, 03:08:55 PM »
Out of interest, have you checked the condition of the stator?
« Reply #82 on: October 02, 2015, 03:18:11 PM »
nope, i walked away in disgust. will be stripping it tomorrow, what am i looking for?
« Reply #83 on: October 02, 2015, 03:22:52 PM »
Either ware on the internal "threads" (rotor should be a reasonably tight fit in the stator) or a circular split at the flange end (you may need to pull it about quite a bit to make the split visible).
New Stator is probably around £50.00.  If you like the pump, it might be cheaper than a replacement pump.
« Reply #84 on: October 02, 2015, 03:46:19 PM »
i like its ability to pump gunge, and seeing as we are approaching gunge season........
i will however be buying one of them cheap chinese things as a backup....
