Simple fat melting and de-watering tank
Overview
20 litre drum sitting inside the tank
A 50 litre cylinder is just the right size to accommodate a 20 litre oil drums and the typical plastic tubs in which fats are often supplied.
To melt fat which has solidified in a drum, the tank is partially filled with water and the drum placed inside to sit on three lugs. Oil could be used for this operation but things might get a little messy!
Preparing the cylinder
Cylinder with bottom safely removed
The cylinder can now be emptied and cut to remove the bottom leaving the threaded connection in place to act as the drain. The cylinder shown was cut with an angle grinder and the edges cleaned up with a file.
Rolling the heater tube
Fitting the heater flange
The heater needs to be mounted as low as possible in the tank to reduce the volume of cold liquid below the element. As the heater is offset from centre, an oval hole needs to be made. Due to the wall thickness of the cylinder the easiest way to cut the hole was to chain drill (no drills were harmed in the making of this tank!) and grind to size with a rotary file. The heater tube can then be welded in place (again, please excuse the tardy welding).
Finishing the tank
With a 50 litre cylinder, the rims of plastic tubs will sit conveniently on the edge of the tank, but three lugs will need to be fitted to support 20 litre drums. These are simply 50mm lengths of steel rod about 10mm diameter, fitted through holes drilled in the cylinder and seal welded externally. To melt fat in drums, the tank is filled with water. A short run of weld can be put on the inside of the tank to mark the appropriate fill level.
Three legs, cut from 1” angle, were welded to the cylinder. Little pads tacked to the ends to prevent the legs digging into the floor.
Using the tank
Typical plastic tub sits neatly inside the tank
Improvements and drawbacks
  • Handles welded to the side of the tank would be a distinct benefit if the tank is to be moved around.
  • Some sort of arrangement to reduce the volume of cold oil beneath the heating element would be an advantage.
  • When used for melting fat in a drum, air can be trapped in the recess formed by the lower seam of the drum, insulating the bottom face. An ‘inverted walking stick’ shaped piece of small bore pipe could be used to vent the air, however, at the time of writing this has yet to be tried.
