Processor - with methanol condenser (GL design)
Graham with his GL processor. Source GL
The GL processor is a design by Graham Laming (hence GL processor) and has probably become most the popular processor design for homebrew biodiesel production in the UK. The processor features built in dewatering and methanol recovery capabilities, as well as protection against exposure to methanol vapour. The design also lends itself to a variety of production techniques.
The design has been in existence for many years. It has been supplemented and improved by various users during this time. Below is a schematic of Graham’s basic design (with sight glass added) along with instructions on its use, which are reproduced with kind permission from Graham. Although the design has been modified by others, Graham’s basic design is capable producing high quality biodiesel and, due to its simplicity, is suitable for those new to home production.
Why isn’t air blown out of the vent?
This is one of the most commonly asked questions. The answer is best described by the diagram above where the fan is located in a chamber. It blows the same volume of air out of the chamber to the left, as it sucks in from the right, so it creates a circulation. There is no vacuum or pressure in the circuit, therefore no air sucks in through, or blows out of, the vent.
The theory is exactly the same in the processor, except in place of a fan you have a venturi (far safer as there are no moving parts). The only time air will come out of the vent is when you add oil or methoxide to the processor or when the oil and air expand whilst heated. Similarly when you drain glycerol or pump out the finished biodiesel, the vent will suck air back in.
Under NO circumstances must the vent be blocked.
This is a compact home made biodiesel processor which avoids water washing and limits methanol release to very small amounts. You can also recover surplus methanol from your biodiesel, which would otherwise be lost in the wash water.
Here's a diagram of the system. It includes a simple venturi to recirculate vapour through a plumbers delight condenser. The venturi also sucks methoxide (or water, if you do the 5% prewash) from the methoxide container and mixes it into the oil flow.
You can mount the methoxide tank up, nearer the venturi, if your venturi's performance is marginal. Make sure it is not too high - you don't want to drop the container, spill the methoxide, or hurt your back.
Process flow
State diagram for the basic GL processor
Step Heater Pump V1 V2 V3 V4 V5 V6 V7 V8 Notes
Oil in Pre-filtered. To check level in processor, stop pump and open valves V2 and V8.
Heat oil 50°C Check level and drain the sight tube before applying heat.
Dewater oil 90°C Switch to 50°C when O/P slows.
Cool oil 50°C Titrate oil now. Empty collector.
Inject methoxide Adj. Allow 20 mins to inject.
Reaction stage Allow 90 mins at 50°C.
5% Prewash Mix 15 mins.
Settle glycerol Wait 90 mins.
Drain glycerol Drain slowly to avoid whirlpool.
Distil methanol 90°C Check level before applying heat.
Drain biodiesel Off Adj. Ensure heater is OFF first! Caution - Hot! Take sample and perform 3/27 test before discharging whole batch.
Step 1. (Oil in)
Step 2. (Heat oil)
Double check that your reactor is filled with the correct amount of oil (75%). Then drain sight tube before turning on the heater. Run the pump with valve V8 open and slightly close valve V2, allowing the pump to suck the sight tube dry. When the tube is empty, close valve V8 and open valve V2.
Step 3. (De-water oil)
  • Open V2 and V6 and V7
  • Switch on the pump
  • Heat the oil to 90C
  • Circulate cold water through the condenser
Switch on the pump.
You don't need to have a fresh supply of water for the condenser. I use a 45 gallon drum of rainwater, which I pump through the condenser and back into the drum again, in a closed loop. I use a household heating circulator pump for this. A few litres a minute is enough if your heater is rated at 3kW.
Step 4. (Cool the oil)
Take a sample of oil from V3, leave it to cool to around 20°C and titrate it, to see how much lye you will need to add to the methanol.
Refit the distillate tank.
Step 5. (Methoxide mixing and injection)
Aim for a feed rate slow enough so the methoxide is fully dosed into the reactor over a period of around 20 minutes. If you dose too fast, the methoxide may flood into the processor so concentrated, that it just floats on top of the oil. You may also get an unwanted gel forming in the piping or tank, which can cause blockages. (Since Graham published this design, it become widely accepted that the methoxide can be introduced at full bore without detrimental effect)
As the tank fills up, the air it displaces (the same volume of air as there was methoxide in the carboy) passes through the condenser and back into the methoxide carboy. The condenser helps to reduce any outgassing of methanol - don't worry about the drips of methanol which collect in the distillate collection tank. It will be very little, and will not affect your reaction. At least you have saved the methanol, rather than venting it out to the air.
Step 6. (The reaction stage)
Step 7. (The 5% prewash)
Fill the methoxide container with water; the amount should be 5% or 1/20th of the amount of oil you dosed the tank with. (Since Graham published this design, it has been found that 7% water can be used offering greater capacity for soap removal without the risk of forming emulsions)
Step 8. (Settle the glycerol)
Step 9. (Drain the glycerol)
Step 10. (Distil Methanol)
If all seems to be working well, switch on your heater, and set your thermostat for 90°C. You will soon see that the rate of methanol collection rises steadily, as you approach and reach the boiling point of methanol in your biodiesel.
Your rate of methanol recovery will depend on many factors, mainly heating power and insulation quality of your tank. I use 3kW heating on 80 litres of biodiesel, with a 'Plumber's delight' condenser 1 metre long. It takes me around 90 minutes to recover around 2 litres of methanol from the 80litres of biodiesel.
When you have finished distilling, SWITCH THE HEATER OFF ! Very important. You do NOT want to drain your biodiesel out of the tank with the heater element still on. As the element becomes exposed, it would glow red hot and ignite any fumes in the tank , with possible lethal effect.
Step 11. (Drain and purify the biodiesel)
Subsequent modifications and additions to Graham's design
Gl processor with additional valve to allow the use of the sight tube during filling.
Additional valve to allow use of sight tube whilst filling
With the arrangement shown above it’s not possible to use the sight tube whilst filling the processor with oil. The addition of one valve will make this possible, shown as valve V9 on the schematic, right (click to enlarge).
With this valve closed, valves V2 and V8 can remain open during the filling operation allowing the sight tube to be used whilst the pump is running.
Higher performance pump
The original design employed a central heating pump, but it has been found a centrifugal pump of around 40l/m (typically a TAM 105 or a Leo XKM60) for an 80 - 100 litre batch size offers better mixing and improves venturi performance. With improved mixing and venturi performance most users no longer find it necessary to introduce the methoxide gradually. It's now common practice to allow the venturi to entrain the methoxide at its maximum rate.
Low oil level interlock
Non siphoning, in-line heater
Mixing eductor
Eductor for an 80 lpm pump. Source: K.H
PID temperature controller
Flash evaporator
Driven by an additional pump, this device often referred to as a “squirrel” for no particular reason, sprays biodiesel into the ullage space of the processor to accelerate the demething process. See Flash evaporator
Still head heat exchanger
Multi tube condenser
