Author Topic: Twin tanking - Peugeot Boxer 350 LWB 2.5D - Minibus/camper/van  (Read 76404 times)
« Reply #75 on: December 12, 2012, 06:35:48 AM »
You should build your controller to sell
http://www.greasecar.com/accessories/co-pilot-computer-controller
cant find my wiring diagrams  :-\ lost um
looks the business though, sounds a good bit of kit, i couldnt get my buzzer to work off the door to warn of not purging as i think it runs on live to switch and not like my old car earth switching, i could prolly sort that but it isnt major or top my list, i had the buzzer on last twin tank. may get round to it sometime...
did you see the 2x valves? one is very different to the other???
« Reply #76 on: December 16, 2012, 08:24:32 PM »
just bagged this 1100 watt inverter for half price  8)
modified sine, not pure.
« Reply #77 on: December 17, 2012, 02:29:05 PM »
update...
well just got me new cramer 2 burner and fitted it in, still need to connect pipes fix sink down and pkumb water gas up, its all there ready, just cant make me mind up if i finished with the worktop being down as i havent screwed it as im always needing to do something or other, hopefully im close, wires / lights i cab get down the window to where needed...
and me made to measure draw tray is in (cut it with saw :) )
enjoy...  8)
« Last Edit: December 17, 2012, 02:30:38 PM by Alessandro Volta »
« Reply #78 on: December 17, 2012, 04:32:00 PM »
Looking good Paul, how much is left to do?
Dick
« Reply #79 on: December 17, 2012, 08:14:12 PM »
Dick
thx dick at least someone cares  :(
 ;D ;D
not much i guess new (RGB mood lighting) and the inverter to fit maybe a few other little things, sort of an on going project keeps me busy
« Last Edit: December 17, 2012, 08:16:15 PM by Shaggy »
« Reply #80 on: December 17, 2012, 08:16:00 PM »
Looks nice, get a bed in there and it could be a shag waggon hahaha
« Reply #81 on: December 17, 2012, 08:17:02 PM »
oh yes need to work out if im going sofa bed or permenant fit?
« Reply #82 on: December 17, 2012, 08:36:55 PM »
Surely some one as sophisticated as you would go for a futon! ;D
« Reply #83 on: December 17, 2012, 08:39:07 PM »
funny you should merntion that, sw one on preloved  ;D
« Reply #84 on: December 17, 2012, 09:28:25 PM »
So then it would be a preloved on a futon? btw where did you get that butt ugly avatar from?
« Reply #85 on: December 17, 2012, 09:31:11 PM »
Correction: it would be shaggy, preloved on a futon  :D
« Reply #86 on: December 18, 2012, 06:25:50 AM »
i used to watch blue peter
http://www.youtube.com/watch?v=PoV2MV3bvvo
« Last Edit: December 18, 2012, 06:54:30 AM by Shaggy »
« Reply #87 on: December 30, 2012, 07:57:40 AM »
heres some update pics to show where i fitted unit
update (re: inverter)
well i got the inverter fitted in and did my first test of one of these things to see what sort of power it uses to biol a kettle of 240 volts, i was quite surprised didnt seem to use much, power was at 12.87v then when kettle was on it went to 11.67v, after a couple of minutes the kettle was bioled and volts went back up close to 12.8, when testing i didnt have engine ~(charging at 13/14 volts) running and the kettle was a 600 watt one, although according the the meter on the inverter that shows either volts or watts, the watts were 430watts to biol kettle and not 600watts as the kettle actually says it is on base.
yes very impressed with this gizmo  8)
« Last Edit: December 30, 2012, 07:02:20 PM by Sexy Santa »
« Reply #88 on: December 30, 2012, 07:14:15 PM »
update re: lights  ;D ;D ;D
got the lights fitted as i had to try stick this 5m strip to carpet ceiling, i used cable clips and replaced the nails with small screws, they work very well.
this is the look without lights on in the dark (nothing much happenning there)
now look at these videos of outside the van and inside the van, quailty isnt great but in reality they are awesome! its the disco van passion wagon hahahaaaa...
im useing the remote control outside the van!
outside vehicle...
http://www.youtube.com/watch?v=_jAvW4k10_Q
inside vehicle...
http://www.youtube.com/watch?v=23M0Yo2JFxE
« Last Edit: December 30, 2012, 07:40:11 PM by Sexy Santa »
« Reply #89 on: December 30, 2012, 07:38:52 PM »
Words fail me  :)
