Author Topic: Twin tanking - Peugeot Boxer 350 LWB 2.5D - Minibus/camper/van  (Read 76363 times)
« Reply #45 on: November 20, 2012, 09:19:22 PM »
gm pipework was wrong hers a new one!
« Last Edit: November 20, 2012, 09:25:02 PM by Rotary-Einstein »
« Reply #46 on: November 20, 2012, 09:25:22 PM »
With the updated pic, I think when you turn the tap on, it can still pull air from the return pipe. Follow it back from the tap, through the pump, and up through the HE.
I think the amount of water your heating, if you covered the bottom of the tank, with like a grid of pipes, it would heat almost as quickly as the coolant.
Seen the new one now. Cant see why that wouldn't work.
Thinking further, I wouldn't be happy bringing the coolant back that far from the syatem, so why not have the HE under the bonnet, and bring two pipes back, into a coil in the water tank. Then you need a pressure release in the system......................
« Last Edit: November 20, 2012, 09:32:01 PM by greasemonkey »
« Reply #47 on: November 20, 2012, 09:38:43 PM »
what you dont know or didnt notice is on the right side of the blue tank in van (other side plywood) are 2x coolant pipes to an extra heater the van come with, its sat between driver seat and passenger seat, so easy to TEE off them and its only say 6 inches from plywoood. drill 2 holes and pipes are in!
« Reply #48 on: November 20, 2012, 09:51:56 PM »
Well thats mighty handy. Is there something already fitted to control the flow in the pipes, or was it in the heater unit?
Its simple to plumb an HE in, in that case, and go with what you've got in the pic. At least with the HE, you haven't got the issue of pressure in the hater tank heating circuit.
« Reply #49 on: November 20, 2012, 09:58:26 PM »
not sure if water through that heater in cab is constant or controlled by unit? i got a switch on dash to turn fan on in the unit to circulate, the pipes both get warm if i remeber? will check it out.
« Reply #50 on: November 20, 2012, 10:02:33 PM »
need to buy an essex flange in about 15mm compression as i cant get inside that blue tank to add the heated water back into tank now...
« Reply #51 on: November 20, 2012, 10:19:11 PM »
could this REALLY? be puished through a hole in a tank with no need to enter into tank? looks odd
http://www.toolstation.com/shop/Heating/Central+Heating/Essex+Flange+15mm/d230/sd2708/p70202
and what is the wire for?
« Reply #52 on: November 20, 2012, 10:24:07 PM »
Yes it can, I fitted and immersion boss to my reactor like that one (just bigger).
The wire is so you don't drop anything inside the tank when you fit it.
« Reply #53 on: November 20, 2012, 10:28:35 PM »
The metal piece of the washer that goes into the tank is split, so you fold it to get it into the hole.  Not that i know any thing about it, but I had a sneaky google when you mentioned them, just so I look like I do :P
Heck of a price on them. Anywhere from £16 to £24.
« Reply #54 on: November 20, 2012, 10:30:15 PM »
hmm bit expensive but i need one
shame bes ones are £5 but min order 50 quid isnt it?
« Reply #55 on: November 22, 2012, 06:56:18 AM »
what temp could my blue water tank take? if useing the above system of engine coolant heated water/tank potentially it could go 80/90c ?
would the blue tank take this, im GUESSING! its HDPE type plastic, it did come out a camper,
« Reply #56 on: November 22, 2012, 07:20:46 PM »
It may have come out of a camper but it was probably only for cold water storage.
If it is HDPE it may have a max temp written on it.
« Reply #57 on: November 24, 2012, 09:42:57 AM »
did have a quick look, couldnt see anything...
HDPE - WIKI page = http://en.wikipedia.org/wiki/High-density_polyethylene
says 120c for short periods, BUT! been reading different pages via the net and some say as low as 65c
i have been given a 12v emertion heater element from kieth (K.H) for testing, not really looked at it yet but not sure if it has a stat in it.... or what wattage it performs at...
« Reply #58 on: November 28, 2012, 06:40:14 AM »
update...
got me a dead man switch in the system now (dont want camper part live all the time) from the split charging second battery i fitted under the drivers seat, with 27amp cables going to the new control panel door / bay compartment, also cut some doors out where cupboards are, and i measured it up so if i do get a fridge later the biggest door can be cut out for a fridge  8) that relay in the pics is a 250 amp jobby, there is a button on the dash control panel if pushed links both batts for cold cranking (or winch useing on 4x4's)
also got a new sink im well happy with that came out an old VW camper, bang tidy with a drainer  ;) thx K.H. i got some goodies for you too bringing them to work today!  :-X
and 240 sockets came out the scrap pile at chugs BBB, sockets for 240 hookup or genny powered (not inverter, be separate bit) thx chug  :)
and leisure battery courtesy of GM greasemonkey's buddy, cheers chap
what would i do without all me buds from the veg sites  ;D
wiring and plumbing all still need doing at the moment front is on for pics so alot of work to do yet, on going project, heres some more pics dudes... enjoy  ;D
« Last Edit: November 28, 2012, 06:59:05 AM by Thomas-Edison »
« Reply #59 on: November 28, 2012, 08:40:42 PM »
@ julian
if i took a picture of a wiring diagram could you decifer it? its not the last take on it but nearly, as it was wiring diagram 20 something and i lost count and got pissed off with making a new one everytime i did an error to post on here, but its basically it... i just did it in my head after...
