Author Topic: Twin tanking - Peugeot Boxer 350 LWB 2.5D - Minibus/camper/van  (Read 76452 times)
« Reply #105 on: March 31, 2013, 08:44:35 PM »
Well you've done your homework on the way that bed folds up. What is the black box in the right hand corner, coming up through the bed?
the motor and oil resivoir for the back lift ramp, just see controller on left with coil of white wire, by side of van under bed
« Last Edit: March 31, 2013, 08:47:02 PM by Donated »
« Reply #106 on: March 31, 2013, 08:45:44 PM »
Mains charger for a vibrator?
thats in the front lol and for bioling a kettle...
« Reply #107 on: March 31, 2013, 08:52:48 PM »
The thing with PLS on it, and some pipes coming out the back?
« Reply #108 on: March 31, 2013, 08:58:21 PM »
as above: its the motor and oil resivior for the tail lift ramp, ramp is under back doors in above picture which says access on it
hydraulic gizmo pump thing
« Reply #109 on: March 31, 2013, 09:03:44 PM »
Sorry, I must be going puddled. Even when you put "as above", I still had to look three times before I saw your post......................
Got it now.
« Reply #110 on: March 31, 2013, 09:05:42 PM »
Got it now.
koolio no worries  ;)
« Reply #111 on: April 11, 2013, 10:26:55 AM »
hi all
only took a couple pics this go, but i have sealed the units with a dye then a linseed oil, also i have fitted th waste water pipe fom the sink now...
gone from this light bare colour to dark, i think it blends in with the van decor quite well
to this now :)
« Reply #112 on: April 27, 2013, 09:35:48 PM »
think i may of got over the nowhere to put the spare wheel due to having an hydraulic lift fitted where the spare wheel carrier used to go, i took a trip to the scrapyard and found a diatsu 4 track and had the back door wheel carrier off it, the studs alignment arnt quite the same as a peugeot boxer wheel but drop on all the same...
the shiny dome topped nuts i found in the dirt right by the scrap car  8)
theres 2 metal plates inside the door to stiffen it all up...
heres some pics folks
« Last Edit: April 27, 2013, 09:41:14 PM by Confucius »
« Reply #113 on: April 27, 2013, 09:38:38 PM »
Looks more and more like a Disco with each set of pictures.
« Reply #114 on: April 27, 2013, 09:43:04 PM »
haha funny you should mention that first 4x4 i tried the carrier off was a disco in the scrapyard, the yard looked more like a disco graveyard plenty to choose from
 :o
 ;D
« Reply #115 on: April 27, 2013, 09:45:26 PM »
I'd be concerned that the wheel is going to bounce around and buckle the door. Can you get a piece of ply wood to distribute the load on the inside of the door? Nice idea though. Tidy.
"theres 2 metal plates inside the door to stiffen it all up..."
Missed that. No flys on you, but you can see where they've been.......... ;D
« Last Edit: April 27, 2013, 09:49:21 PM by greasemonkey »
« Reply #116 on: April 27, 2013, 09:49:16 PM »
re wrote/edited first post on this part topic.
theres 2 metal plates inside door top and bottom bolts aswell and the door itself has brasing bars structure inside it as standard, plus wheel pulls right in tight to door all round so works very well
« Reply #117 on: April 27, 2013, 09:49:54 PM »
Posts overlapped :)
« Reply #118 on: April 27, 2013, 09:54:18 PM »
also i pulled the BOXER sign off the door from underneath the wheel and im going to fit it on the other door under the PEUGEOT sign
« Reply #119 on: April 27, 2013, 10:00:03 PM »
Not quite sure why you'd want to display either ... I have a Land Rover badge spare but it's rater expensive as they are highly sought after.
