Welcome,
Guest
. Please
login
or
register
February 15, 2026, 02:24:14 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
General
Alternative heat and power
DIY syphon nozzle
« previous
next »
Print
Pages:
1
3
4
5
Author
Topic: DIY syphon nozzle (Read 38153 times)
julianf
Wiki Editor
Grand Gunge Master
Re: DIY syphon nozzle
Reply #60 on:
July 30, 2015, 09:19:59 PM »
this one may be better -
http://heating.danfoss.com/PCMPDF/BFP10-11_VDDKQ202.pdf
shows settings for one pipe, or looped opperation.
it may be interesting for you to stick a pressure gauge on it also, but possibly not, if youre never going to be pumping at pressure.
Logged
For custom cnc cut instrument panels, see -
http://www.thebeast.co.uk
Collections website -
http://www.devon-used-cooking-oil-collection.co.uk
Tony
Administrator
Oil baron
Fo' shizzle, biodizzle
Reply #61 on:
August 06, 2015, 10:38:22 AM »
Next problem.
I have a motor EOGB M02-1-90-13 (brand new one, for cheap!) and aforementioned Danfoss BFP 11L3 pump (I understand L means left hand, rotates anti-clockwise), the two fit together but need some form of coupling to join them.
Is this the right coupling? Are Riello and Danfoss pumps interchangable?
http://www.ebay.co.uk/itm/RIELLO-OIL-PUMP-DRIVE-COUPLING-RDB-AND-MECTRON-3000443-/191624698084
Or something like this?
http://www.ebay.co.uk/itm/BENTONE-SINGLE-STEP-DRIVE-COUPLING-C01-00-117-56802-SIMEL-AEG-B9-Pump-dog-/141607047964
(nearly a fiver for a bit of plastic ain't happening, I'd rather print one)
Last Edit: August 06, 2015, 12:26:11 PM by Tony
Logged
therecklessengineer
Administrator
Oil obsessive
Reply #62 on:
August 06, 2015, 01:19:51 PM »
A bit of hose and two jubilee clips works quite nicely if you're not too bothered about a 'proper' engineering solution.
Logged
Waste oil collection in Somerset
Tony
Administrator
Oil baron
Reply #63 on:
August 06, 2015, 01:30:04 PM »
Hehe I like your thinking!
Sadly this is not a shaft to shaft coupling, the pump has a shaft with a flat and the motor has a recessed pocket in the back that takes some keyed coupler.
Logged
Chug
Administrator
Oil obsessive
Reply #64 on:
August 07, 2015, 12:44:46 AM »
mine are in parts like this,
http://www.uk-plumbing.com/eogb-drive-coupling-inter-11-10-12-109-99-p-55576.html
Last Edit: August 07, 2015, 12:47:03 AM by Chug
Logged
Print
Pages:
1
3
4
5
« previous
next »
General
DIY syphon nozzle
