Author Topic: Turbo wanted, puny ones need not apply! >:(  (Read 9151 times)
« on: March 25, 2014, 12:45:57 AM »
As per the BBB thread I would like to build  a jet type engine using a turbo. There are lots of videos on the tube and there is a guy called colin furze (or something similar) who makes the most entertaining ones:
https://www.youtube.com/watch?v=Gh34A0b8MrE
I want a big turbo not a puny one, something off a lorry or a bus. Any one know what engines have big turbo's? I tried looking on ebay but did not find anything. There are some big ones for petrol engines but they are mega expensive. This is just for fun and demo at the BBB so don't want to spend hundreds of pounds on the turbo.
Also will need help with welding, though I may just buy a tig welder and break the world record for the worlds biggest pigeon turd laid on steel! hahaha ;D ;D
Any way if you have one laying about and don't have a use for it or can suggest where I can get one from I would be delighted.
Cheers
Re: Turbo wanted, puny ones need not apply! >:(
« Reply #1 on: March 25, 2014, 06:26:56 AM »
Great idea!  Me and friend from uni (Pete) made one a couple of years back, we used a lorry turbo of some sort from the scrap yard.  We used a saab PAS pump for the oil supply and a wiper motor to drive it slowly enough not to over-pressurise the turbo.  A spark plug and a relay wired in to itself to generate a constant on-off-on-off for a coil and spark (just to start the engine) (the relay didn't last long doing that :) )  We drilled out a regulator and ran the engine from a patio gas bottle and an electric leaf blower to start the engine up.  The whole lot cost about £40 all from the scrappo :)   It can certainly be done cheap.
We had a proper Whittle moment and it was perched on a chair in the garden while my friend kept turning up the gas regulator and nothing happened, then it exploded into life and started accelerating (with the regulator fully open).  We panicked and ran away as it accelerated like mad, then my friend grew a pair and ran back to pull the gas regulator off the bottle.  It was so much fun!
This was before Furze had done any jet engine stuff.  Colin Furze is a friend of my friend Pete.  We did the engine in a weekend the other side of the country in Stamford, I went home and Pete showed Colin some time later, then Colin put the engine in a BBQ frame and made the worlds first Jet BBQ, it was pretty funny.  We put a sausage in the exhaust heat and it got fired across the garden.  I think one of the sky channels did a piece on the Jet BBQ.  Colin is a very talented fabricator, and Pete is a very talented engineering, between them they've done some other jet powered things, The pulse jet bike being a good un.  Colin has made a Jettle (that's right a jet powered Kettle), and Pete is currently working on a valve type pulse jet powered lawn mower.  This is truely insane with 80% the power of the buzzing bomb!!
« Reply #2 on: March 25, 2014, 06:29:16 AM »
« Reply #3 on: March 25, 2014, 06:30:12 AM »
Correction..
We ran the pump from a drill, it was Colin that put the wiper motor on when he did the BBQ conversion.
« Reply #4 on: March 25, 2014, 08:55:44 AM »
This big enough?  :o
Seriously though, we do have a spare turbo from a 350kW CAT genset. It's about 250mm diameter. It can't be returned and it's just sat gathering dust. If you're interested I can see if I can convince the powers that be to part with it.
« Last Edit: March 25, 2014, 09:10:33 AM by therecklessengineer »
« Reply #5 on: March 25, 2014, 09:26:02 AM »
Do it, do it, do it, do it!  :)
You'll get some proper propulsion with that!
« Reply #6 on: March 25, 2014, 09:31:23 AM »
This kind of welding you want MIG. Or arc.
Not saying you can't do it with TIG, but it'll take you hours and consume large quantities of gas. MIG and arc are much better for welding big thick lumps of steel, unless it needs to be perfect for some reason.
« Reply #7 on: March 25, 2014, 01:39:58 PM »
This big enough?  :o
Hi James,
Yes that is lovely! I would love to have that!!!!!! I don't really know much about welding but I wanted to learn TIG, I have had a go at ARC, I say had a go.... there was 3 or 4 pages of abuse at my attempt hahaha
I will look around on ebay for a decent 2nd hand one and avoid the Chinese ones.
Loz, Yeah Colin seems like a good bloke and is quite funny. I have seen most of his videos on youtube.
Now this being a bio/veg forum effort I would like to run it off bio or veg. How would that happen? Can I start it on propane and switch over when its hot enough?
« Reply #8 on: March 25, 2014, 02:57:13 PM »
This big enough?  :o
Hi James,
Don't know the technicalities, but didn't Virgin experimentally run ½ the engines of a transatlantic flight on bio a while back?
« Reply #9 on: March 25, 2014, 02:58:21 PM »
Didn't Virgin Atlantic fly one of its planes with one engine running on bio?
« Reply #10 on: March 25, 2014, 03:01:17 PM »
I think it's your age ... (lol)
« Reply #11 on: March 25, 2014, 03:15:13 PM »
No it's you butting in whilst I was preparing me veg for dinner.
« Reply #12 on: March 25, 2014, 03:15:53 PM »
To run it off bio or veg I think the fuel needs to be pressurised and atomised, otherwise it probably won't burn properly. It would mean adding some sort of compressed air into the fuel system and some sort of injector.
« Reply #13 on: March 25, 2014, 04:05:23 PM »
This one is for you Julian:
https://www.youtube.com/watch?v=6rX4xv5-NvE
hahaha
« Reply #14 on: March 25, 2014, 04:19:19 PM »
I'll knock one of those up before tea.
