Author Topic: need help  (Read 12653 times)
Re: tony you online need help
« Reply #45 on: October 03, 2013, 11:00:27 PM »
I suspect that it is the Configuration page that is currently wrong - namely that the forwarding rules do not have a device associated with the,
« Reply #46 on: October 03, 2013, 11:02:37 PM »
« Reply #47 on: October 03, 2013, 11:07:34 PM »
This guide is even better, it lists the two ports given by your DVR (80 and 34567) and is for a very similar device.
If you decide to use 80 and 34567 then you will need to change the ports on the DVR menu back to those from whatever you have set them to at the moment.
« Reply #48 on: October 03, 2013, 11:09:05 PM »
doesnt matter what i use port wise get same hanging screen and nothing on internet
« Reply #49 on: October 03, 2013, 11:11:07 PM »
« Reply #50 on: October 03, 2013, 11:21:59 PM »
I dont think I can help you any more mate. If those rules are allocated to the DVR118N device and that device has the correct local IP then it should work.
Maybe you should take up Arash's offer of remote connection and let him try to sort it out
Off to bed now anyway, good luck with it.
« Reply #51 on: October 03, 2013, 11:32:25 PM »
thx jules been a diamond friend... night...
« Reply #52 on: October 04, 2013, 07:36:54 PM »
hi
well i put some more settings in the DVR, details for no-ip.biz, think its ok
arash did you want to come in on my pc and have a look?
Re: need help
« Reply #53 on: October 05, 2013, 07:07:24 PM »
Hi Paul,
Have you got a smart phone? iphone or android type thing that has mobile internet on it?
Re: need help
« Reply #54 on: October 05, 2013, 07:30:08 PM »
Hi Paul,
only when next to my router via wifi
or if i use BT-Fon hotspots elsewhere
i have andriod
teamveiwer is loaded on my pc
Re: need help
« Reply #55 on: October 05, 2013, 09:16:59 PM »
Hi mate
PM me your telephone number and I will try and sort it for you.
cheers
Re: need help
« Reply #56 on: October 06, 2013, 05:44:51 PM »
Hi mate
cheers
im pretty much done with it, it is infact my friends system next door and he doesnt have internet in his house so he has a ethernet cable through the wall to his neighbours router for access via the net and his DVR.
i can wifi in to next doors router i have the pass, and i can get to next doors DVR as i have the key, hes been away all weekend.
your welcome to get in on me pc to prod about in settings if you wish, i can log into tnext doors router.
Re: need help
« Reply #57 on: October 06, 2013, 06:48:52 PM »
Every time I peer at this thread someone has answered all the technical stuff already :)
NAT is a tricky thing, as said above all you need to know is you have two distinct networks, your house - Local Area Network (LAN: typically 192.168.x.x addresses) and the rest of the internet - Wide Area Network (WAN: everything else).
Your modem/router will have a WAN address which anyone on the internet can connect to.  Network Address Translation  (NAT) is the translation between WAN and LAN.  So you need to tell your router how to take a WAN access and connect it to one of your LAN machines (in this case your PVR).  This is done by port forwarding.
So say you access your WAN address with a web browser, it will connect to your WAN IP address on port 80 and effectively say "gimme a webpage".
If you have that port 80 forwarded to your PVR, then that router will pass it on to the PVR, so the PVR sees "gimme a webpage" and will return it to the router which passes it on via the WAN side to the web browser that requested it.
Sounds more complicated than it is!
So all you need is a rule that takes WAN port 80, and maps it to a LAN address also on port 80.
The only complication is that your WAN address can keep changing, which is where the whole dyndns type thing helps (gives it a name which tracks the WAN address)
I guess a lot of that has been covered above but figured a recap in different words might help :)
Re: need help
« Reply #58 on: October 06, 2013, 07:15:04 PM »
think i done all that, thats why its confusing me, i know port forwarding, just missing something somewhere
i have a ni-ip account which is in router and DVR if inputted correctly no idea? but alsong as router doesnt power down and back on the wan addy should be same but cant get shizz on it.
locally i get the DVR log in page in IE browser
Re: need help
« Reply #59 on: October 06, 2013, 07:35:13 PM »
Your IP:   86.149.241.49
What Port?   80
Success: I can see your service on 86.149.241.49 on port (80)
Your ISP is not blocking port 80
