Tips and wrinkles 1
See also tips and wrinkles 2.
- 1 Drip catcher
- 2 Spill gutter
- 3 Condenser tell-tail
- 4 Foot strainer
- 5 Barrel pick up pipe
- 6 Flying hose holders
- 7 Winged jubilee clips
- 10 Thermocouple pocket
- 11 Homemade sock filters
- 12 Human centrifuge
- 13 Strong back dome puller
- 16 J cloth wrapped filter
- 17 WVO core sample tube
- 19 Funnel / bucket filter
- 20 Non glugging pourer
Drip catcher
- Drip catcher
Spill gutter
- Spill gutter
Condenser tell-tail
- Condenser tell-tail
Foot strainer
- Foot strainer
Barrel pick up pipe
- Pick up pipe
Flying hose holders
- Flying hose holders
If you use flying hoses to move oil, glycerol or biodiesel around these make life a whole lot easer. It’s not an original idea, but it’s a cheap and easy way of making quick to use hose clips.
- Winged jubilee clips
- Temperature panel
Thermocouple pocket
- Thermocouple pocket
Dimensions will obviously vary according to requirements, but typically start with a rectangle, the length of which equal to the height of the sock required. The width will be dictated by the length of garden hose used to create the collar. Provided the diameter of the collar is about 25mm larger than the hole in which the sock is suspended it shouldn’t pull through, even when full of oil. Make the width the length of the hose plus 50mm to allow for two seams.
- Homemade sock filters
Human centrifuge
- Human centrifuge
- Dome puller
Adding a black bin liner over cubie or carbouy containers helps absorb the suns radiated heat to speed up the settling process and drop the suspended water and fats more quickly.
- The diagram
An excelent idea from bobblake is to wrap a J cloth or similar around a filter element which will act as a 'pre-filter'. Held in place with twisted wire or another biodiesel/oil proof material, it's cheap, easly changed and will prolong the life of the element.
- Filter saver
A great idea comes from Kenr34 on the infopop forum in the US.
- Core Sample Tube
- click to enlarge
KH 22:40, 25 June 2011 (BST)
Non glugging pourer
This differs from others in that it doesnt require making a hole in the cubie rendering it useless.
Flexable spout for ease of use.
Very simple and cheap and it only uses the lid.
Parts List:
- lid with a hole cut in it,
- Jubilee clip,
- wire eg coat hanger,
- plastic tank connector,
The tank connector goes in the lid and then fix the large pipe to it with a jubilee clip.
Now glue the smaller pipe inside the large pipe with approx 16" extending out(roughly the measurement from the lid to the opposite top corner), put the stiff wire inside the small pipe and fold to keep in place.
Cut the pipes and wire diagonally so the small pipe is at the top and the bend small pipe so that it goes into the top corner of a cubie. If you leave the tank connector with a bit of movement you can alter where it points when it's tightened up.
- click to enlarge
KH 22:39, 25 June 2011 (BST)
