Processing with anhydrous sodium methylate
This page gives a guide to making biodiesel from anhydrous sodium methylate (ASM), a liquid catalyst which can be used in place of the more conventional sodium hydroxide or potassium hydroxide catalysts.
Calculating how much to use
mL of methylate = ((Base Amount + Titration Value) X Batch Volume in Litres) X 5
This is based upon the use of a 0.1% sodium hydroxide titration reference solution (ie the normal 1g of sodium hydroxide in 1 litre of de-ionised water that most of us use and also known as lye water).
As an example : assuming a batch size of 150 Litres, a titration of 2.0g/L (using 0.1% NaOH titration reference solution fluid) and using a base value of 5.0 g/L gives
((5.0 + 2.0) X 150) X 5 = 5250mL of methylate
Whilst it is perfectly possible to use a single stage reaction for making biodiesel, many brewers are now taking advantage of the benefits of the two stage process with no titration with it's reduced chemical usage, reduced soap production and better yields.
mL of methylate = (Base Figure X Batch Volume) X 5
mL of methylate = (Base Figure X Unconverted Litres) X 5
First stage : mL of methylate = (150 X 4.0) X 5 = 3000mL
Second stage : mL of methylate = (30 X 4.0) X 5 = 600mL
Mixing
The ease of mixing is without doubt the best feature of mixing sodium methylate. Using conventional solid catalysts is a labour intensive process. Whilst potassium hydroxide flakes dissolve relatively easily in methanol, sodium hydroxide micro pearl is more trouble and full sized sodium hydroxide pearl requires significant effort.
Mixing sodium methylate and methanol is an almost instantaneous process, comparable to mixing fruit cordial with water since both are liquids.
Reducing the methanol volume
The second advantage of using methylate is that around 70% of the fluid is actually methanol. This means that less methanol needs to be added to the batch. Conventional wisdom has been around 20% methanol using solid catalysts whereas using sodium methylate this can be reduced significantly.
A real world example
For the first stage: Methanol volume = 12% X 150litres = 18 litres, methylate volume = 5 X (4.0 X 150) = 3000ml
For the second stage, which has 30 uncoverted litres: methanol volume = 12% X 30litres = 3.6 litres, methylate volume = 5 X (4.0 X 30) = 600ml
Giving a total of 21.6 litres of methanol and 3.6 litres of methylate
The pros and cons of using anhydrous sodium methylate
Pros
Cons
