Silver soldering
Brazing techniques - General
Brazing is a similar process to soldering, allowing metallic parts to be joined permanently by flowing in an alloy with a lower melting point than the parts to be joined. The molten alloy in turn alloys with the hot substrate, forming an extremely strong bond. Most brazing processes exhibit a degree of capillary action, having the ability to "wick" into joints and form a large fused area while presenting a minimal bead profile outside the joint.
Copper pipe connections silver soldered to a FPHE.
Silver soldering or hard soldering
Silver soldering may be used to join copper, brass, iron, steel, high-speed steel and (with a special flux) stainless steel.
Classic brazing
Heating techniques
Aluminium torch brazing
An example of aluminium brazing done with a MAPP gas torch and fluxless rods.
Brazing aluminium is a superficially similar to the processes mentioned above, but different in several very important ways.
Aluminium dip brazing
