Casting a venturi
Pipe fitting venturi body and aluminium cores. By Uberderv
Cores
Steel
Aluminium
Wood
Plaster
Core geometry and dimensions
Screw connected cores. By NigelB
Body
Components of pipe fitting venturi body
Fabricated body
Pipe fitting body
Casting
A simple biodiesel burner will produce a nice sooty flame.
NigelBs cores clamping a pipe fitting body together.
G clamp and wood blocks with a fabricated body.
Tin can crucible with Mole Grip handle.
A better soot generator can be made from a night light casing filled with biodiesel, into which a large wick is placed. The wick can be supported by twisting a piece of wire around it. Biodiesel will burn with a very sooty flame and greatly speed the process. see cphoto right.
Finishing
Internal view after successful casting. By Uberderv.
Venturi cast with steel cores and throat drilled to size
Successfully drilled suction port. By NigelB
