Biodiesel process guide
(Redirected from Biodiesel Fast Track Guide)
This is a fast guide to the steps involved in making biodiesel according to the simplest process.
Process overview
This diagram shows the popular methods employed by brewers to produce biodiesel from used vegetable oil. Which parts of the process are followed come down to personal choice. The simplest path is detailed on this page.
Pre-process
Dewatering
- Take a sample for titration
Process
- Add 10ml of IPA to a beaker
Mix methoxide
Mix methoxide and oil
Post-process
Drain glycerol
Finishing
Choose one of:
Finishing - GL processors
Finishing - Non-GL processors (waterless)
Finishing - Water washing
- Dry the wet biodiesel
Soap tests
