3/27 test
(Redirected from 5/45 test)
The test
5/45 test with unconverted vegetable oil present (Source: BassAddict)
How it works
The test works because of the difference in solubility of vegetable oil and biodiesel in methanol:
  • Biodiesel is soluble
  • Glycerol is soluble
  • Monoglycerides and diglycerides (partly converted vegetable oil) are partially soluble
  • Vegetable oil (triglycerides) is insoluble
When mixed, any remaining vegetable oil, which is denser than methanol, will drop to the bottom.
Any volumes can be used so long as the ratio is 1:9 sample to methanol. 5/45 also represents common quantities used for this test.
Trace glycerol may be present in the sample, but this won't affect the test, as it too is soluble in methanol.
Qualitative not quantitative
Many brewers assume that by measuring the amount of vegetable oil that has dropped out, they can calculate the percentage of unconverted oil in the batch. This is, however, not strictly correct, as the sample will contain a small amount of glycerol and an unknown quantity of methanol, depending on how much has been used by the reaction.
Clear pass
5/45 "clear pass" and 5/45 pass.
Perfectly converted fuel will give a "clear pass" where the liquid is transparent, regardless of the methanol temperature.
Cloudy liquid with no drop out at 20°C is considered a pass, but may contain mono and diglycerides. Drop out may be seen if the liquid cools.
The only caveat with using methanol cooler than 20°C is that (depending on feedstock) even completely converted biodiesel may wax and also give the appearance of drop-out as a result. For corn and rapeseed oils this is quite light in colour and distinguishable from unprocessed oil, however solidifying palm oil is quite dark and the distinction may not be so obvious.
Jan's email is reproduced below:
Reply-To: Biofuel@sustainablelists.org
To: <Biofuel@sustainablelists.org>
Subject: Re: Biofuel Quality Test
Date: Thu, 11 Aug 2005 18:51:02 +0200
Hello Jeffery.
Take exactly 25 ml of biodiesel and dissolve it in exactly 225 ml of methanol in a measuring glass.
Now: The biodiesel should be fully soluble in the methanol forming a clear bright phase. If not, there is pollution in the biodiesel causing you trouble with the water test. Each ml of undissolved material is corresponding to 4% by volume. Are there any undissolved material at the bottom of the measuring glass ?
Good luck to you
Jan Warnqvist
AGERATEC AB
