Author Topic: welding  (Read 7584 times)
welding
« on: February 16, 2013, 08:27:59 PM »
hi all
can i arc weld stainless and iron?
need to put lugs on like this pic
« Last Edit: February 17, 2013, 10:39:03 AM by Rm Jaz a.k.a Teflon Shank »
Re: welding
« Reply #1 on: February 16, 2013, 08:42:21 PM »
You need His Royal Trumpetness, he will know
Re: welding
« Reply #2 on: February 16, 2013, 08:52:24 PM »
where is the roving wonderer ?
 :o
Re: welding
« Reply #3 on: February 16, 2013, 09:57:28 PM »
Hi shank
Yes you can arc stainless and iron  , you need to use dissimilar rods and be carefully with the different melt temps.
As said above Jim is the realy guy for fine details on this
Re: welding
« Reply #4 on: February 16, 2013, 10:00:16 PM »
thx
dissimilar ???
wats dat
Re: welding
« Reply #5 on: February 16, 2013, 10:05:04 PM »
It a rod for welding metals that arn't the same (dissimilar).
The weld will take on the characteristic of the ferrous metal.
Hope this helps till you get better advice
Paul
Re: welding
« Reply #6 on: February 16, 2013, 10:07:33 PM »
From what I understand (I'm not a welder) cast iron can be welded, but will often crack along the edge of the weld if put under any strain.
Dissimilar rods are for welding two dissimilar metals, you need the right type depending on what metals they are.
Re: welding
« Reply #7 on: February 16, 2013, 10:54:50 PM »
hey mark
its not cast
just iron or steel, one of um? how do i tell???
Re: welding
« Reply #8 on: February 16, 2013, 11:09:36 PM »
Your pic doesn't work for me.
Re: welding
« Reply #9 on: February 16, 2013, 11:20:19 PM »
is it the glove on one hand?
Re: welding
« Reply #10 on: February 16, 2013, 11:42:57 PM »
Now Now boy's play nicely, anyway back to the other rods, the welding ones.
You can weld stainless to mild steel using either stainless or standard steel rods BUT it's better to use stainless rods to prevent the  stainless component rusting along the fusion line.
Re: welding
« Reply #11 on: February 16, 2013, 11:54:18 PM »
Not the friggin avatar the one in the first post
Re: welding
« Reply #12 on: February 17, 2013, 12:09:27 AM »
it was an FB link i wasnt sure it  would load anyone else see it?
Re: welding
« Reply #13 on: February 17, 2013, 12:10:40 AM »
What?
Re: welding
« Reply #14 on: February 17, 2013, 12:14:47 AM »
