Author Topic: Serious pump and houseing = offers  (Read 16630 times)
Offline Ats
Re: Serious pump and houseing = offers
« Reply #32 on: February 25, 2013, 10:50:02 AM »
If you can find a Variable Frequency Drive (with single phase input) cheap enough, then that would also drive a three phase motor - with the advantage of being able to change the speed/soft start/reverse etc.
« Reply #33 on: February 25, 2013, 10:52:08 AM »
Hang on did you say that was 8.5kW?  I don't think the inverter above is rated that high.  And a VFD of that power would be big $$$.
« Reply #34 on: February 25, 2013, 12:02:57 PM »
yes spec on that pump says 8.5 that is a beast of 11HP
above bit of kit stated by the owner can only go to 4HP so not good for this but may come in handy for other uses or members sheds  ;)
