Author Topic: Serious pump and houseing = offers  (Read 16631 times)
Re: Serious pump and houseing = offers
« Reply #15 on: February 24, 2013, 01:13:12 PM »
Do you know what frame size the 3ph motor is?  If it's 71 frame for example it could easily be replaced.
no idea of what that is?
« Reply #16 on: February 24, 2013, 01:21:10 PM »
I think Knighty or William can use 3 phase?
are they users on here?, im not goin g over vod to post...
Yes they're on VOD, do you want me to u2u them a link to this thread ?
Or should I just post a link to this thread over there ?
« Last Edit: February 24, 2013, 01:32:50 PM by mark »
« Reply #17 on: February 24, 2013, 01:44:06 PM »
yeaah post away
« Reply #18 on: February 24, 2013, 02:19:56 PM »
William crosby is a member on here, not sure about Knighty can't check at the mo
« Reply #19 on: February 24, 2013, 04:18:20 PM »
Nathan...what's 71 frame?....never heard of that.
I feel some education coming on.
Nige
« Reply #20 on: February 24, 2013, 04:27:57 PM »
Nige
 im waiting to know that one, wonder if its fitting bolts or shaft drive?
« Reply #21 on: February 24, 2013, 06:04:05 PM »
I've just googled 71 frame. Not really sure if I read it right but it looks as though it relates to the body, flange or both. 3 phase is still 3 phase............unless I've read it and got it wrong.....which can be quite often and regular. ;D
« Reply #22 on: February 24, 2013, 06:18:02 PM »
its 415 v so to me at a guess thats 3 phase
« Reply #24 on: February 24, 2013, 06:36:28 PM »
As I understand it, the frame size is the area of the motor's flange, where it bolts to a pump for example.  I guess the best way to measure this is by measuring the centres between the holes on the motor's flange (is this called pcd?). You also need to measure the diameter of the shaft and it helps to know if it there is a keyway on the shaft.
3phases I think are more efficient, so a 3 phase 0.37kw motor could be 63 frame size, whereas the 1ph equivalent would be 71 frame.  I suspect that you could get a 3ph 0.37kw motor in 71 frame though.
Common shaft sizes are 11mm 14mm and 18mm
« Last Edit: February 24, 2013, 06:41:21 PM by nathanrobo »
« Reply #25 on: February 24, 2013, 06:38:48 PM »
Converting 3ph to single phase will be at the cost of the motor's power.  An electrical engineer will give more precise info, but a 1/2 hp motor at 3ph could be less than 1/3hp converted to 1ph.  Probably not the best way forward.
« Reply #26 on: February 24, 2013, 06:54:35 PM »
heres some more info on that ebay add
Quote
For sale here is a very  little used single phase to three phase converter. It was bough for my previous workshop that had no 3 phase power, to run a 4HP milling machine. The machine only ran once or twice a year, and I moved after 18 months, and now have 3 phase. Perfect for the home model maker, it has several different setting to suit your machine size. I can send this by Fedex Overnight for £10.00. or collect from Littlehampton, West Sussex for free.  Low starting price and no reserve. Good luck
« Reply #27 on: February 24, 2013, 06:57:18 PM »
wow
8.5 kilowatts = 11.3986878 hp
that off spec plate of that pump
« Reply #28 on: February 24, 2013, 06:59:37 PM »
wow
My wordy... that's a big motor!
« Reply #29 on: February 24, 2013, 07:04:08 PM »
wow
you could pressure filter with that baby lol
