Author Topic: Quick release couplings?  (Read 17374 times)
Re: Quick release couplings?
« Reply #15 on: January 29, 2013, 02:10:34 PM »
That's interesting.  At the risk of going too far off topic there used to be a bio producer down my way that winterised his commercial biodiesel with Methanol.
« Reply #16 on: January 29, 2013, 03:21:54 PM »
Watch this... if the installers of the aluminium-finned flame arrester had known it, then two of the chaps fitting the roof may not have died.
https://www.youtube.com/watch?v=yYgJcnzr_2k
Scary stuff!
Nasty. Easy to see how it could happen. Seems a bit thtupid making the flash arrestor out of aluminium in the first place mind. Its surely going to corrode up over time, with or without the Methanol. Although, to be fair, they did say it should have been serviced every 12 months.
« Reply #17 on: January 30, 2013, 07:51:23 PM »
Im looking for a quick release coupling that shuts the flow off when disconnected, these look like they may be suitable but im not sure that they shut the flow off, any opinions?
 http://www.ebay.co.uk/itm/MACDONALD-Male-Female-Hydraulic-Quick-Release-Action-Coupling-Type-HF-/130831671887?pt=LH_DefaultDomain_3&hash=item1e762ce24f&_uhb=1
Where / how were you thinking of using them?
« Reply #18 on: January 30, 2013, 08:10:39 PM »
When i bund the wash tank and processor the wvo storage tank will be a few feet away, so thats what they are for, the one i linked to arrived today and does NOT shut off  :(
« Reply #19 on: January 30, 2013, 08:15:47 PM »
Stick something in the hole then like your di finger.
« Reply #20 on: January 30, 2013, 08:20:11 PM »
The Filtertechnik ones seal perfectly.  They use them on the rigs, so it could be worth a call to Mike - see if they'll sell them as a part.
« Last Edit: January 31, 2013, 10:00:25 AM by nathanrobo »
« Reply #21 on: January 30, 2013, 08:23:50 PM »
Its only a small hole, im sure you have something small i can borrow!
« Reply #22 on: January 30, 2013, 08:27:10 PM »
I was under the impression you have a VERY small di er little finger, well so a certain lady told something like that at the BBB.
« Reply #23 on: January 30, 2013, 08:31:12 PM »
Chunder is NO lady, ladies dont kiss and tell!
« Reply #24 on: January 31, 2013, 10:05:47 AM »
Some of these -
http://www.oilybits.com/hose-couplings-reels/hose-connectors/cam-and-groove-couplings/prod_290.html
I think with all due consideration, despite being Aluminium, if these are used for oil transfer then they should be fine.  I may well have to save up for a few of these for the new processor.  Do the different "types" just designate different pipe fitments (male/female bsp/barb)?
What is the "Viton seal" they talk about?  Is that just a sealing o-ring?
« Reply #25 on: January 31, 2013, 11:59:10 AM »
so far as i can tell -
type a/d are a paid for connecting to male bsp
type c/e for hoses
type b/f for female bsp
and then, of course, you can mix and match as you see fit.
i want to get some for my mono pump - i use it for general purpose veg shifting, so it has a suction tube and a 30m 3/4 hose attatched... permenantly - which does not make for much fun when i want to move it about.
i dont think theyre 'complex' like the iso couplers, so i suspect the seal just sits in a recess somwhere, and, as it says -
All Fittings are supplied as standard with NBR seals, with Viton and NBR Filled Teflon (PTFE) available seperately
the stator in my mono is not viton, so ive never given these seals much thought!
« Reply #26 on: January 31, 2013, 02:25:35 PM »
Aha! so it is true about the tryst with our Chunder, I thought he was pulling my leg when he told me.
Oh ye', he said can he have is pants back, they're the only ones he has without holes in'm.
« Reply #27 on: January 31, 2013, 04:12:34 PM »
Sorry no can do, last I saw of them they were powering a sailing ship across the Atlantic
« Reply #28 on: January 31, 2013, 08:04:58 PM »
So from your last two replies you're confirming there has been a relationship with said lady and that you kept his pants as a trophy.
Nuff said.
« Reply #29 on: January 31, 2013, 09:01:43 PM »
Jealousy can be a terrible thing!
Oh and the other half wants to know who your avatar is?
