Author Topic: No wonder I've had lumpy starting  (Read 34091 times)
Re: No wonder I've had lumpy starting
« Reply #30 on: December 16, 2012, 07:53:08 PM »
I presume it would be a bad idea to fill the cylinder with oil/water, then refit the injector, hydraulically locking it, then trying to push the glow plug tip out by turning the engine by hand?
Might break something I suppose, or pop the head gasket.  Just throwing the thought out there!
The only issue with that Tony is when turning the engine by hand the valves will start to open thereby losing any compression. I suppose by determining the compression stroke would help.
Offline william crosby
« Reply #31 on: December 16, 2012, 07:53:46 PM »
a diesel engine will give a compression test of about 350 psi thats why never use petrol tester on a diesel
Offline Bio Dervotee
« Reply #32 on: December 16, 2012, 07:58:17 PM »
Compression ratio is about 20 to 1, so about 20bar/300psi,  detonation pressure will be in hundreds/thousands of bars
« Reply #33 on: December 16, 2012, 09:07:56 PM »
This thread shows a cross sectional view of the problem area.
http://forums.vwvortex.com/showthread.php?5478522-20v-ALH-running-diesel.
Have you kept any of the other plugs, Nige? If so, cut a tip off and see what diameter of (long) easi-out you would need to tap in...or just use a tap, as thread isn't the issue. I would then let the stuck tip soak in PB Blaster or similar for a couple of days, then 'tap' the connection into the tip so as to attach something that will work like a slide hammer.
The compressed air might work as well if yoy can get that kit.
« Reply #34 on: December 16, 2012, 09:12:43 PM »
threaded part came out easy the hot tip end came off and fell in chamber
« Reply #35 on: December 16, 2012, 09:20:38 PM »
I know!
As I read it, the tip was assumed to be stuck in normal position, not fallen in to the chamber. The advice was on how to get the tip out.
« Reply #36 on: December 16, 2012, 09:24:20 PM »
I know!
i beg ya pudding, i read wrong i thought it fell off, ok so its stuck in situe, yeah may be bad that one...
thought they looked same as these though
« Last Edit: December 16, 2012, 09:27:52 PM by Alessandro Volta »
« Reply #37 on: December 16, 2012, 09:31:45 PM »
My biggest fear of tapping into the broken tip would be if the tip then fell into the combustion chamber. I know that the worst case scenario is removing the head but if possible it would be great to remove the tip without resorting to such measures.
I wonder if araldite would work. You know...try glueing the two parts together and attempting extraction. Do you think that would work. I've still got the broken plug so it is feasable
« Reply #38 on: December 16, 2012, 09:33:28 PM »
what part/position at did it snap off on glow plug?
« Reply #39 on: December 16, 2012, 09:34:44 PM »
What about araldite on the end of a steel rod so you can tap it to try and release it?
« Reply #40 on: December 16, 2012, 09:39:54 PM »
It snapped off just below the champhered seat where the plug seals into the head. The black tip is still there and will not move under normal engine compression. I've ran the engine til normal operating temperature was acheived and it showed no sign of moving
« Reply #41 on: December 16, 2012, 09:43:52 PM »
so to clarify if under normal circumstances there would be a gap bettween probe body and cylindrical chamber its in the center of?
and now its held in by carbon deposits.
all the main steel body came out ok though?
« Last Edit: December 16, 2012, 09:45:59 PM by Alessandro Volta »
« Reply #42 on: December 16, 2012, 09:45:00 PM »
Worth a go... but I'd doubt the tensile capabilities of the bond; that bugger is near-welded in with carbon.
Beru glow plugs shear off at around 90 Nm, arounf twice the install torque figure.
« Reply #43 on: December 16, 2012, 09:47:23 PM »
Is there anything that will dissolve carbon? an oven type cleaner maybe, pour some in the hole, leave, then run the engine?
« Reply #44 on: December 16, 2012, 09:50:11 PM »
If the carbon dissolves with the engine running there is the likelyhood of the tip falling in the combustion chamber and stuffing the engine
