Author Topic: upping new pic for twin tank pipes/layout  (Read 8242 times)
« on: December 11, 2010, 10:02:54 PM »
as above
stay tuned.... ::)
Re: upping new pic for twin tank pipes/layout
« Reply #1 on: December 11, 2010, 10:09:19 PM »
Nice pic  ;D
« Reply #3 on: December 11, 2010, 10:21:34 PM »
heated filter upped now
« Reply #4 on: December 11, 2010, 11:00:33 PM »
I done a graphic too, took most of the evening! http://www.biopowered.co.uk/wiki/GL_Processor
« Reply #5 on: December 11, 2010, 11:02:42 PM »
check my link again! alot more pics
still upping will check your link shortly...
well done chap :)
« Reply #6 on: December 11, 2010, 11:12:16 PM »
friggin awesome!!!
the oil in? where from?
love this diagram.
what app drew that?
« Reply #7 on: December 11, 2010, 11:16:07 PM »
disstillate part where does it come from? can only see a vent pipe?
« Reply #8 on: December 11, 2010, 11:22:03 PM »
It's done in CorelDRAW which is vector software not a bitmap.  You have a lot more flexibility with vector drawings, but have to export them as a bitmap when finished.
The vapour circuit is from the connection on the top of the tank, through the condenser,back up and right to the venturi, which creates the suction/circulation for the circuit.  The distillate (Water or Methanol, depending on the process) drops out in the condenser and runs into the distillate collection vessel.  As the flow of distillate is very small it doesn't need a separate vent because it vents up the same tube.
« Reply #9 on: December 11, 2010, 11:23:47 PM »
Sorry, missed this bit ... Oil in from settling tank.
« Reply #10 on: December 11, 2010, 11:24:20 PM »
do you need a valve straight after venturi? to stop flow and make go to other 2 valves direction?
« Reply #11 on: December 11, 2010, 11:28:19 PM »
wont liquid going up vent pipe from distilate get half way up vent pipe and go down to glycerol container?
« Reply #12 on: December 11, 2010, 11:30:42 PM »
By it's design, oil won't go up the venturi suction unless the open pipe in the tank is blocked off. See http://www.biopowered.co.uk/wiki/Casting_a_venturi  or better still the venturi page when it's done!
The world of Bio is much more interesting that the veg world ... go on admit it!
« Reply #13 on: December 11, 2010, 11:36:09 PM »
impressive, but very confusing, truth for me is im lost.... with process.
build is baffling me aswell and routes for each part of process...
« Reply #14 on: December 11, 2010, 11:40:07 PM »
also i didnt mean venturi
im talking vent pipes only...
distilate you say goes up vent pipe, the vent pipe which is teed to the glycerol vent pipe in glycerol container, what stops (whatever goes up vent pipe from distialte = no idea) going down glycerol pipe vent into glycerol container????
