Welcome,
Guest
. Please
login
or
register
March 26, 2026, 07:09:08 PM
Wiki
Forum
Tools
Titration calculator
No-titration calculator
Pump pressure vs head
Oil heating calculator
Venturi and eductor throat
Drum cone calculator
Oil price trends
Recent Posts
Help
Search
Login
Register
General
Wiki and forum discussion
upping new pic for twin tank pipes/layout
« previous
next »
Print
Pages:
1
2
Author
Topic: upping new pic for twin tank pipes/layout (Read 8240 times)
Julian
Administrator
Oil baron
Re: upping new pic for twin tank pipes/layout
Reply #15 on:
December 11, 2010, 11:48:45 PM »
There shouldn't be any liquid in the vapour circuit at the Tee off for the glycerol vent, it should have all come out in the condenser. Anyhow there's no flow through the glycerol container because its sealed and the drain valve is closed. The flow will only go to the venturi. Even if it were open it still won't take that route due to the circulating effect of the venturi see this diagram by GL
Logged
Used Cooking Oil Collection website ...
http://www.surreyusedcookingoilcollection.palmergroup.co.uk
Rotary-Motion
Wiki Editor
Oil baron
Reply #16 on:
December 12, 2010, 12:05:38 AM »
very interesting drawing!
what temp is the oil/process at to give off vapour to go to condensor?
is it methoxide going in distillate?
Logged
Julian
Administrator
Oil baron
Reply #17 on:
December 12, 2010, 12:18:37 AM »
You can remove water from the oil, usually between 60 and 90°C and once converted remove the methanol from the bio or bio and glycerol if WBD between 40 and 75°C. Temps can vary depending on how much you want to get out.
The best basic knowledge can be had from GLs website at
http://www.graham-laming.com/bd/ecosystem/state_diagram_new.htm
This is where I copied the diagram from, he explains the process far better than I can.
Logged
Rotary-Motion
Wiki Editor
Oil baron
Reply #18 on:
December 12, 2010, 09:34:58 AM »
what is WBD ?
Logged
Julian
Administrator
Oil baron
Reply #19 on:
December 12, 2010, 10:13:49 AM »
http://www.biopowered.co.uk/wiki/Acronyms
and
http://www.biopowered.co.uk/wiki/Whole_Batch_Demeth
Logged
Rotary-Motion
Wiki Editor
Oil baron
Reply #20 on:
December 12, 2010, 10:14:40 AM »
thanks hehehe
i already tryed our system... it works...
Logged
Print
Pages:
1
2
« previous
next »
General
