Author Topic: Venturi formula  (Read 17042 times)
Re: Venturi formula
« Reply #30 on: September 08, 2012, 09:35:53 AM »
Just goes to show the importance of keeping it as simple as possible.
Would it be worth adding a venturi calculator too? (I know I've not finished the cone one yet, it will happen!)
I didn't add one before because I figured the formula alone was enough but by the sound of it, it would be useful to have one.  And we could potentially add eductor jet size to that as well.
Re: Venturi formula
« Reply #31 on: September 08, 2012, 10:22:26 AM »
I'd go for it.  The object of the site is to provide info and assist people.  I'm happy to do new diagrams if required, just let me know.
Re: Venturi formula
« Reply #32 on: September 10, 2012, 09:53:21 AM »
I've added the venturi calculator here:
http://www.biopowered.co.uk/forum/tools/throat.php
(Also in menu above).
Re: Venturi formula
« Reply #33 on: September 10, 2012, 10:48:39 AM »
OK think I've got it now:
http://www.biopowered.co.uk/forum/tools/cone.php
Will verify the maths later (javascript is in radians so it's possible I've made a conversion mistake somewhere).
« Last Edit: September 10, 2012, 03:24:19 PM by Tony »
Re: Venturi formula
« Reply #34 on: September 10, 2012, 11:01:12 AM »
Looks good.  I can do a couple of graphics to explain the terminology, one for the input and one for the output.  Can they be inserted in the boxes on the righthand side?
What about the hole in the top for the fitting?  Similar calculation to the main OD I assume.
Re: Venturi formula
« Reply #35 on: September 10, 2012, 11:37:44 AM »
Graphics could be inserted either to the left or right of the params/results section. I was thinking that for the time being we could just insert James' hand drawn diagram.
Re: Venturi formula
« Reply #36 on: September 10, 2012, 12:08:03 PM »
Probably better if I modify the two top diagrams here ... http://www.biopowered.co.uk/wiki/Cone_bottoms_for_tanks
Just need to know what you are going to call the fitting cutout diameter.
Re: Venturi formula
« Reply #37 on: September 10, 2012, 12:18:21 PM »
That works. Lets use it!
Re: Venturi formula
« Reply #38 on: September 10, 2012, 12:31:07 PM »
Just modifying them now.
Would it be more useful to give the cone height rather than the flat cone diameter?
Re: Venturi formula
« Reply #39 on: September 10, 2012, 12:49:35 PM »
First diagram here ... http://www.biopowered.co.uk/wiki/File:Cone_diagram_1.png
Let me know if it's a suitable size.  I know it can be re-sized, but that will effect the text.
Re: Venturi formula
« Reply #40 on: September 10, 2012, 01:18:17 PM »
Second one's uploaded ... http://www.biopowered.co.uk/wiki/File:Cone_diagram_2.png
Very much like the idea of offering the chord dimension, saves people measuring angles.
I've gone with radiuses instead if diameters as that's what people will be using to construct the cone.
Re: Venturi formula
« Reply #41 on: September 10, 2012, 01:37:36 PM »
Nice one Julian, I've added both those, obviously some tweaking will be needed.
Regarding angle vs height, you anticipate that these should both be input parameters (the user choses which one they want to use and the other is updated automatically?)
Edit: done those changes
Maybe needs the fitting diameter added to the top diagram for clarity?
« Last Edit: September 10, 2012, 02:09:22 PM by Tony »
Re: Venturi formula
« Reply #42 on: September 10, 2012, 04:58:53 PM »
Good work with the calculator, think the height bit is a big bonus.  But I think the layout with the graphics could do with improving and the text has come out different sizes.  Strange, because it the same text, exported at the same size.
How about I redo the second graphic to be two pairs, one above the other.  That way you can shunt the graphics off to the right which will, I think, stop the page looking so cramped.
Also for consistency and clarity, I'll letter the remaining dimensions and angles. I'll not use Greek for he angles, just lower case (makes it easy if not quite correct)
Re: Venturi formula
« Reply #43 on: September 10, 2012, 05:51:15 PM »
Are they any better?
Re: Venturi formula
« Reply #44 on: September 10, 2012, 05:58:10 PM »
Just noticed you've added volume too ... brilliant!
