Author Topic: Water injection for ring gumming  (Read 186 times)
Offline Vijay
« on: October 30, 2025, 11:06:22 AM »
Morning,
I need to start doing this before my engine gets worse, hopefully the smoking and oil usage is down to gumming and I can save it. I'm hoping to install my system properly when I get more time
Just wondered what the right procedure is for misting water into the inlet pipe when the car is stationary? Engine warmed up, revs raised (to??) and then short bursts of spray?   How much water over what period?
Any idea if it is ring gumming how long it would take to notice any reversal?
Cheers
Vijay
Re: Water injection for ring gumming
« Reply #1 on: October 30, 2025, 01:24:14 PM »
What car?
Offline Vijay
« Reply #2 on: November 03, 2025, 09:24:11 AM »
2004 Skoda Octavia 1.9 ASV 110 engine
« Reply #3 on: November 04, 2025, 07:41:01 PM »
Hello Vijay, I hope all is good with you?
We did 1500 -2000 rpm and we used a couple of litres over about 40-45 mins from a garden pump up sprayer set on its finest mist the first time on my mates peugeot, then he did a few more between 15 -30 mins and said it was much improved and then he was gonna fit a nozzle and pump on a switch but the car was back ended and written off.
Offline Vijay
« Reply #4 on: November 12, 2025, 09:32:36 AM »
Hello mate,
Yeah all good apart from crazily busy these days. How you been?
Appreciate the info, deffo got to try it this weekend. Sorry to hear about his car though, not the end I hoped to hear lol
Offline Vijay
« Reply #5 on: November 16, 2025, 09:30:22 PM »
put through 2.5 litres of deionized water today. Held the car at 1500 revs while I sprayed it through over 45 minutes to an hour.
I found the revs would drop once sprayed and then come back. Every now and again the revs would rise higher which I didn't quite understand.
Would also see a bit more smoke when the revs would clime back up.
What else should I expect to see in the process?
Offline Vijay
« Reply #6 on: November 17, 2025, 08:34:59 AM »
Checked the engine oil this morning and I have some emulsion. Did I spray too much water, or too quickly or is my engine just knackered?
Offline Vijay
« Reply #7 on: November 18, 2025, 10:20:40 AM »
I took the car out for a "spirited" drive yesterday and it drove really well. Apart from my car needing a jump start (new battery ordered yesterday), it started pretty well and a huge reduction in smoke, I'm talking 90% reduced at least. I know it's way too early but I'm quite shocked at how much less smoke there was.
I've topped it up with diesel and took it for a high rev drive and again it drove fantastically.
« Reply #8 on: November 18, 2025, 11:59:54 AM »
Did the Italian tune up get rid of the emulsion?
Offline Vijay
« Reply #9 on: November 18, 2025, 08:34:08 PM »
nah still some in there. I didn't think the emulsion would go until I did an oil change?
Offline Vijay
« Reply #10 on: November 19, 2025, 09:22:48 AM »
Still did well on next to no smoke this morning, I'd be very happy if this worked as it was so bad. Still have to see about oil usage though.
Offline Vijay
« Reply #11 on: November 19, 2025, 07:56:48 PM »
There was next to no emulsion in the oil today, do you think it could have steamed off?
