Author Topic: Steel immersion bosses  (Read 10761 times)
« on: July 13, 2012, 10:08:34 AM »
Mark pointed out to me that since they are so deep they can easily be cut in half to make two.  So mine are off with a mate for a bit of lathe work today :)  Two will become four!
« Last Edit: July 14, 2012, 10:46:45 AM by tony »
Re: Steel immersion bosses
« Reply #1 on: July 13, 2012, 04:42:50 PM »
Spice girls, 1996?
« Reply #2 on: July 14, 2012, 09:43:29 AM »
Spice girls, 1996?
Ah yes when Geri Halliwell was quite attractive - before she did the boney skinny thing!
« Reply #3 on: July 16, 2012, 10:26:00 AM »
Happy days :)
Will have a go at an inline heater using disposable gas bottle.
« Reply #4 on: July 16, 2012, 03:13:01 PM »
Nice job!
Don't forget to take lots of photos, we don't yet have a page on in-line heaters.
There's something I thought of a while back and never got round to trying.  It's for creating the shape of the hole where the inlet and outlet, tangentially intersect the body ... try setting up the pipe, just spaced above the body, and shine a light from directly above.  It may cast a shadow of the pipe on the body.
Be interesting to see if it works.
« Reply #5 on: July 16, 2012, 05:00:27 PM »
Hey that's a good idea.
I have a set of these HSS burrs to use making the odd port shapes prior to welding on the pipe:
http://www.ebay.co.uk/itm/HSS-Rotary-Burrs-5-piece-set-/120937802232
Cheap - will see how they perform vs the thick steel on those disposable argon bottles.
« Reply #6 on: July 16, 2012, 07:59:56 PM »
I used similar, but cheaper looking, ones on my (non)gas cylinder, after chain drilling the hole.
Offline Stumpy
« Reply #7 on: July 22, 2012, 11:14:35 PM »
Where can I get one from please chaps..   ::)
Titless process
WBD
Hardwood polish
Free Hardwood shavings/sawdust if collected.
« Reply #8 on: July 22, 2012, 11:18:06 PM »
Mine were commissioned by Keith, but I think Steve (e3msb) sells them on VOD, £12 for one or £22 for two delivered.
I don't know if Steve's are big enough to machine down into two like Keith's were.
Offline Stumpy
« Reply #9 on: July 22, 2012, 11:24:58 PM »
Cheers Tony Ill u2u them both and see ..
Titless process
WBD
Hardwood polish
« Reply #10 on: July 23, 2012, 09:54:59 AM »
You could try the method shown at the bottom of this page ... http://www.biopowered.co.uk/wiki/Fitting_a_heater_flange
« Reply #11 on: July 23, 2012, 07:06:53 PM »
Sorry,all mine went a while ago and James has since had my tap,not sure if Steve has any and you would need to ask the size as the pic he uses is mine
This might be of interest
http://www.vegetableoildiesel.co.uk/forum/viewthread.php?tid=28278&page=1#pid368835
« Last Edit: July 23, 2012, 07:10:08 PM by K.H »
« Reply #12 on: July 23, 2012, 07:58:15 PM »
Keith, from your past experience, did you buy pipe the correct ID to be threaded with your tap?
I'm just wondering if they would be any more economical to produce by thread cutting on the lathe.
« Reply #13 on: July 23, 2012, 08:19:24 PM »
Yes i came across a short length (40") of 3" wide tube,internal diameter of 2 3/8 and walls of 8ml and they ended up been done on a lathe,thats why i let Jim have the tap,but as i dont have a lathe i was paying to have them made
« Reply #14 on: July 23, 2012, 08:26:42 PM »
Done on a lathe with your tap or with a thread cutting tool?
