Author Topic: Hydrometer - is this OK?  (Read 3937 times)
« on: March 21, 2022, 10:21:50 AM »
Never had one, never used one but think I prolly should have one to test methanol. This is advertised for home brewers, will it work OK for bio?
If yes, when I test where on the scale ideally do I want to be if my methanol is good?
https://www.amazon.co.uk/Hydrometer-Included-Millimeter-Trial-Sampling/dp/B0722QYJSZ/ref=sr_1_5?crid=3184IB2TSGHVO&keywords=hydrometer&qid=1647857876&sprefix=%2Caps%2C144&sr=8-5
Ta.
Offline DavidA
Re: Hydrometer - is this OK?
« Reply #1 on: March 21, 2022, 02:32:52 PM »
Hi,
You may find that hydrometer scale a bit cramped.
I have one that measures from 775 to 825. It is very easy to read.
It easily shows the problem of water appearing in your methanol.
I am trying to find out where I got it (years ago) but suspect it is from Stevenson-reeves.
I'll let you know if I can find the details.
« Reply #2 on: March 21, 2022, 05:40:14 PM »
« Last Edit: March 21, 2022, 06:02:00 PM by neisel »
Offline countrypaul
« Reply #4 on: March 21, 2022, 06:22:07 PM »
You need to look for relatively small amounts of water in methanol, so really you need to cover the 90-100% alcohol range. The density of methanol is around the 0.8 mark depending on temperature (it is quite sensitive) - Graham Laming's site has a table documenting purity against temperature with resulting densities reproduced here: http://biopowered.co.uk/wiki/Testing_methanol_purity
Something like: https://www.fishersci.co.uk/shop/products/range-finder-hydrometer-5/12841428#?keyword=hydrometer
« Last Edit: March 21, 2022, 06:34:45 PM by countrypaul »
Offline DavidA
« Reply #5 on: March 21, 2022, 07:36:03 PM »
neisel,
Here are a few more details on the hydrometer I suggested.
http://stevenson-reeves.co.uk/hydrometers/LANS.htm
And
« Reply #6 on: March 21, 2022, 09:16:54 PM »
Julian,
Don't remember.
You borrowed mine ... a long time ago!
