Testing methanol purity
Specific gravity
Testing with a hydrometer
Hydrometers
Also suitable, but not quite so accurate, is a Trellis hydrometer used in home brewing. These often read in % alcohol, proof or ABV (alcohol by volume). They will be based on ethanol which comprises the bulk of alcohol found in common beverages. Ethanol has an SG of 0.789, so very close to methanol, not as accurate as a laboratory version, but good enough for our needs if economy is an overriding factor.
Hydrometer trail jar
In addition to the hydrometer, you will need what’s known as a trial or test jar. This is simply a tall, preferably transparent jar in which the hydrometer will float without touching the sides or bottom. A measuring cylinder is ideal, but these can be quite expensive in larger sizes.
A cheaper alternative can be constructed at home. The one pictured below was made in a few minutes using scrap materials. As the cylinder isn't transparent, it's necessary to fill it to the top in order to see the reading. In operation the tube is filled to the top and the hydrometer inserted. The liquid displaced is caught by the cup surrounding the tube.
As an alternative to the above method of construction, the base could be cast in lead. Lead could be melted into a suitably sized tin lid and a length of 28mm, or larger, copper or steel tube with the end tinned placed just below the surface of the molten lead and the assembly allowed to cool. The cup could be constructed in the same way as the photos above.
Reading a hydrometer
If you are using a transparent trial jar, fill it with sufficient methanol to allow the hydrometer to float well clear of the bottom. Give it a gentle spin to remove any air bubbles and allow it to settle. The SG can be read from the scale
The following table is reproduced with kind permission of Graham Laming:
% pure 0°C 10°C 15°C 20°C
90 0.8374 0.8287 0.8239 0.8202
91 0.8347 0.8261 0.8212 0.8174
92 0.832 0.8234 0.8185 0.8146
93 0.8293 0.8208 0.8157 0.8118
94 0.8266 0.818 0.8129 0.809
95 0.824 0.8152 0.8101 0.8062
96 0.8212 0.8124 0.8073 0.8034
97 0.8186 0.8096 0.8045 0.8005
98 0.8158 0.8068 0.8016 0.7976
99 0.813 0.804 0.7987 0.7948
100 0.8102 0.8009 0.7959 0.7917
Testing by weight
