Author Topic: Helical gear with damaged teeth  (Read 1907 times)
Offline Vijay
« on: July 28, 2021, 06:58:17 PM »
Just wondered if you guys had any suggestions how I can fix/replace a helical gear on an old chopsaw I have. The teeth are pretty scredded up and not available from the manufacturer as a part. Just seems a shame to throw a complete machine away cos of a gear :(
Re: Helical gear with damaged teeth
« Reply #1 on: July 28, 2021, 09:54:00 PM »
I had a cheap chop saw similarly fail with the reduction gear losing teeth.
The only realistic option here (for 1% of the population) is to buy / find another cheap, faulty one for spares to fix it.
« Reply #2 on: July 29, 2021, 12:18:45 AM »
You can buy pre-cut gears from various suppliers.
Only issue would be if yours have special bosses, but it's worth a search or two.
Offline Vijay
« Reply #3 on: July 29, 2021, 01:19:32 PM »
That's exactly what a place an engineering mate said, find a donor. Likelyhood is very small that I'll find one, local and with the gear in good condition :(
Offline Vijay
« Reply #4 on: July 29, 2021, 01:20:17 PM »
Looked on Ebay and Google but didn't amount to much. Any ideas what sort of places I should be searching?
« Reply #5 on: July 29, 2021, 05:51:39 PM »
These people are pretty good although I haven't bought gears from them.
https://www.hpcgears.com/
There will be many others, but you'll have to search for them ... it's not really the thing you'll find on ebay.
You could also consider a redesign and fit a toothed belt drive instead.  Loads of info on line.
Offline Vijay
« Reply #6 on: August 01, 2021, 11:34:03 AM »
Thanks Julian, will have a look though and contact them  :)
