Author Topic: Pump help needed  (Read 5865 times)
Re: Pump help needed
« Reply #15 on: August 22, 2016, 10:36:11 PM »
Oops
« Reply #16 on: August 23, 2016, 04:02:17 PM »
Thats very kind of you, im between Oxford and Cheltenham, probably easiest if i arrange a courier if it suits you?
sounds good to me
I'll PM you my work address and you can get it picked up whenever suits you
(it's bloody heavy mind)
let me dig it out first and I'll get you dimensions/weight :-)
EDIT: I could stick it on a small pallet and send it to you like that, it's normally under £20 for 3 day service
« Reply #17 on: August 23, 2016, 04:45:19 PM »
Last bit sounds good, pm your Paypal address and i can pay you, then send it at your leisure?
« Reply #18 on: August 23, 2016, 06:20:57 PM »
That's a rather nice gear pump, do you think it would pump potassium glyc (for, say, a burner nozzle)?
« Reply #19 on: August 23, 2016, 08:26:53 PM »
Errrr what fiendish scheme are you planning now?  ;D
« Last Edit: August 23, 2016, 08:45:20 PM by K.H »
« Reply #20 on: August 23, 2016, 08:51:53 PM »
Mahusive flame thrower for next years BBB ?
« Reply #21 on: August 23, 2016, 09:16:06 PM »
I dare say some kind of bypass valve might be required to not deliver 12lpm of glyc into the flame :)
To only success I've had with pumping glyc for a burner nozzle was with a car windscreen washer gear pump, but that kept slipping the gears on the motor shafts with liquid as dense as glyc.  I've also tried a dispensing machine vane pump (popped the front cover circlips off), so I've been hunting a small gear pump...
But, that said, with the house move and the work the new place requires, I very much doubt I'll have time to play with atomising burners for a while.
« Reply #22 on: September 11, 2016, 07:27:26 PM »
sounds good to me
Any luck finding it yet Knighty? :)
« Reply #23 on: September 12, 2016, 05:51:56 PM »
I know where it is... and I can see it... but I need to shift some stuff with the forklift to get to it... and need to shift a car to get the forklift in... and need to shift the van to shift the car
(car is on a trailer, van has no engine)
but.. I'm tidying up this weekend so will be able to get it out then no problem :-)
« Reply #24 on: September 12, 2016, 08:15:57 PM »
There was an oil lady that swallowed a fly........................................................
« Reply #25 on: September 12, 2016, 08:42:39 PM »
Sounds familiar, i know some things are in my garage, some where :)
« Reply #26 on: September 22, 2016, 04:03:17 PM »
I've dug it out, PM me your adress and I'll send it down on a pallet next week :-)
