Author Topic: Pump help needed  (Read 5865 times)
Pump help needed
« on: August 21, 2016, 11:25:05 AM »
I have this Hydraulic oil pump and i need a rough idea of LPM, cant find anything on this model on the web, so can anybody make a guess?
« Last Edit: August 21, 2016, 08:20:49 PM by K.H »
Re: Pump help needed
« Reply #1 on: August 21, 2016, 12:09:08 PM »
Looks like a gear pump, so the flow will be low. Around 12 lpm at a guess.
Why don't you set it up and time the flow.
If it is anything to go by the pump manufacturers presently advertise two oberdorfer type pumps. One has a flow of 2.5 litres/min and the other about 3.2 litres/min.
« Last Edit: August 21, 2016, 01:31:29 PM by dgs »
« Reply #2 on: August 21, 2016, 06:32:38 PM »
I agree. It will be a gear pump and low Lpm. If you think about it, presuming it is for a ram, then you don't want the ram moving too fast else you can't control it.
« Reply #3 on: August 21, 2016, 07:58:43 PM »
Yes its definately a gear pump, low LPM is what i want to hear  :D
« Reply #4 on: August 21, 2016, 07:59:47 PM »
looking on their web page I can't see any of their pumps rates to 2800rpm ?
(just moved, so internet via mobile phone right now, bit slow, maybe I missed some?)
either way, gear pumps flow rate is pretty flat as pressure increases, so flow rate with no pressure shouldn't be miles away from flow rate against pressure
but... the front section of the pump with the gears in it looks quite long to me... and has pretty large ports, 1inch?   which would make me think it's higher flow rate lower pressure?
« Reply #5 on: August 21, 2016, 08:22:12 PM »
The pump bit is just the ally piece, rest seems to be an adaptor plate thing?
« Reply #6 on: August 21, 2016, 08:29:13 PM »
There'll be a spider drive in that adaptor plate thing.
What are you planning to use it for ?
« Reply #7 on: August 21, 2016, 08:36:06 PM »
It came off a log splitter so im thinking of building one myself
« Reply #8 on: August 22, 2016, 09:07:34 AM »
just saw your thread about an oil tank too
I've got a 12v hydraulic pump, built onto an oil tank that would easy work a log splitter if you want it ?
power it with an old 12v battery and a battery charger ?
needs decent power cables to it, it pulls a fair few amps, I think I might have some, they're only short but that's all you need ?
« Reply #9 on: August 22, 2016, 11:22:10 AM »
That sounds ideal, save me lugging a genny about, pm with how much you want
« Reply #10 on: August 22, 2016, 03:02:15 PM »
you can have it
dad bought it years ago from a fisherman who used it to power his pot haller thing, we used it for a tail lift, but it's sat for about 5 years not not getting used, might as well go to a good home :-)
where abouts are you again ?  down south somewhere?
there's a chance I might be able to get it dropped off around essex area some time - maybe relay it on from there ?
« Reply #11 on: August 22, 2016, 08:30:25 PM »
Thats very kind of you, im between Oxford and Cheltenham, probably easiest if i arrange a courier if it suits you?
« Reply #12 on: August 22, 2016, 09:49:21 PM »
You told me you'd moved!
« Reply #13 on: August 22, 2016, 09:53:36 PM »
Ah bugger, caught out!
Are you sure i said that? you havent been on the vino again have you?
« Reply #14 on: August 22, 2016, 10:15:19 PM »
OK, I have to be honest, you didn't say that ... you put it in writing.
