Author Topic: Minigun for BBB 2016?  (Read 26140 times)
Re: Minigun for BBB 2016?
« Reply #45 on: May 19, 2016, 07:08:08 PM »
I can get an offcut of rubber conveyor belt, about 5mm thick reinforced 3 ply, that should make a good strong gasket.
What size do we want ?
I think some crosshairs on the base of the tube would be good to stop the tennis ball going into the chamber.
« Reply #46 on: May 19, 2016, 07:17:59 PM »
That conveyor belt rubber make brilliant sound deadening in cars.  I had my old series Land Rover decked out with the stuff.
« Reply #47 on: May 19, 2016, 07:25:36 PM »
Bloody 'eavy though, it's the density that absorbs the sound.
« Reply #48 on: May 19, 2016, 10:06:23 PM »
For the gasket 8" x 8" would be ideal as for the crosshairs a single 8mm nut and bolt should suffice unless the tennis ball
is an interference fit in the pipe then it could loaded via the chamber prior to inserting the charge.
« Reply #49 on: May 20, 2016, 03:36:18 AM »
8 x 8 it is then.
« Reply #50 on: May 20, 2016, 01:09:02 PM »
cover yours balls in grease and they should get to the next county :o
« Reply #51 on: May 20, 2016, 08:07:04 PM »
Can we set the grease on fire.
« Reply #52 on: May 20, 2016, 08:37:45 PM »
cover yours balls in grease and they should get to the next  county.
We'll have to draw straws to see WHICH the poor unlucky sod has the pleasure of greasing YOUR balls.
Not something I'd want to be involved in.
« Last Edit: May 20, 2016, 08:39:21 PM by Jamesrl »
« Reply #53 on: May 20, 2016, 09:11:12 PM »
We'll have to draw straws to see WHICH TWO poor unlucky sod has the pleasure of greasing YOUR balls, one each.
I taken the liberty of editing your post.
« Reply #54 on: May 21, 2016, 01:08:43 AM »
thats a shame i was looking forward to it.
« Reply #55 on: May 21, 2016, 01:22:17 AM »
OK Bobby the jobs yours but is it ok if we watch and take piccies?
« Reply #56 on: May 21, 2016, 10:12:22 AM »
No point using expensive grease someone must have some old manky kebab fat.
« Reply #57 on: May 21, 2016, 12:00:08 PM »
Ye' the stinkier and more rancid the better.
« Reply #58 on: May 21, 2016, 12:22:21 PM »
the prospects get more exciting by the minute. as i wont be there i can send a couple of balls for you all to play  with. it's ok i don't want them back.
« Reply #59 on: May 21, 2016, 12:40:40 PM »
WHAT!!!!!! You'd get y'self castrated just for our entertainment?
Don't worry Bob, I only want to see the Womble's ball flying out that tube.
