Author Topic: Automated valves  (Read 3007 times)
Automated valves
« on: July 19, 2015, 09:02:46 PM »
I know the subject has been discussed several times but I haven't seen anyone produce one yet.
I just came across this on Thingiverse ... http://www.thingiverse.com/thing:932431/#instructions
I know it probably won't take the sort of temperatures we use, but I'm sure the design could be adapted.
Re: Automated valves
« Reply #1 on: July 19, 2015, 09:11:43 PM »
A standard 1/4 turn ball valve could be adapted with gear quadrant and worm
and two micro switches for travel limit.
« Reply #2 on: July 19, 2015, 09:59:40 PM »
I swa the ac bloke at work messing about with something similar, might get the worn one off him for experimentation.
« Reply #3 on: July 20, 2015, 02:40:40 PM »
I like that idea, possibly could do away with the microswitches if you can detect the stall current (like car windows do).
« Reply #4 on: July 20, 2015, 05:48:23 PM »
I always intended to use an electric mechanism from a car door lock on a ball valve. No need to detect current then, just pulse in one direction or the other.
