Author Topic: Bio-Powered No-Titration Calculator  (Read 9034 times)
Offline Bio-boy
« on: June 20, 2015, 01:51:44 PM »
Just a question in relation to the calculator on this site and it is with regards to the % methanol in the calculator and the figure quoted.
For example:
If you wish to use 20% methanol by volume for say 100L WVO that would equate to 20L of methanol yet the calculator states 16L???
Is this a flaw in the calculator?
Re: Bio-Powered No-Titration Calculator
« Reply #1 on: June 20, 2015, 01:56:51 PM »
I dont know about the details of the calculator, but...
my feeling is that, if you used 20% on s1, that, in itself, may cause issues with the glyc dropping (aside from just being wasteful)
I use 10% for both stages.  Makes calculations very easy also! : )
Offline Bio-boy
« Reply #2 on: June 20, 2015, 02:13:32 PM »
Julian does your process include a glyc wash?
I don't glyc wash but have been using the no-titration calculator to good effect. However, it would appear that 20% in the calculator is actually 16%. However, I would be keen to hear your process as 10% for stage 1 and 2 would save me even more methanol.
« Reply #3 on: June 20, 2015, 03:15:54 PM »
The calculator takes 80% of the "Methoxide by volume" figure as the methanol volume for stage 1.  That must be from the 80/20 split for two-staging.  Then if you have fallout in the 10/90 test the other 20% is used for stage 2.
If there is a better way to present this, or we're happy to use a fixed 16% for stage one and 4% for stage 2 then we can drop the "Methoxide by volume" box altogether.  Opinions welcome.
Offline Bio-boy
« Reply #4 on: June 20, 2015, 03:40:40 PM »
Now I am confused - although that doesn't take much.
My interpretation of the calculator I think is incorrect. This is how I interpret it:
130L WVO - add 20.8L methanol to 910g KOH (7g Base) and introduce to reactor. React for 1.5hrs and then allow glycerol to drop for 1/2 hour and complete a 10/90 test then drain glycerol. Input drop out figure into calculator (for example 2ml) which equates to an additional 5.2L and 182g of KOH. React for a further hour and then retest using 10/90 test and hopefully this should give a clear pass.
Is this correct?
« Reply #5 on: June 20, 2015, 04:51:09 PM »
Yes.  But, of course, the glyc is hardly full of excess chem either.
I did try, a couple of batches back, adding some caustic to the glyc (dissolved in a tiny amount of meth) as it seems like a good idea... Im not sure it made much difference though, but then my oil is not all from the same place anyhow.
If you use no-titration with variable oil, you need to get a 'feel' for what's what, else you can over / under do things (eg, if you know its manky oil, maybe increase the s1 catalyst a bit etc)
I generally go for 10% / 5g ltr of unconverted on each stage.  Others do the same, with good results.
Offline Bio-boy
« Reply #6 on: June 20, 2015, 08:49:55 PM »
Do you pre wash with glyc?
How often do you get a 100% pass following the 2nd stage using the quoted %'s and how often do you require a 3rd stage to obtain a complete reaction?
I will be trying 10% and 5g base for my next batch to see how it fares in comparison to my current 16% and 7g base.
« Reply #7 on: June 20, 2015, 10:04:41 PM »
original post by julianf
The enhanced glycerol pre-wash can make a big difference, but we need to put it into perspective. The idea is to neutralise the FFA's 'in the prescence' of glycerol. This means the water produced from the neutralisation reaction plus any excess water in the oil will be absorbed into the glycerol. You will then in theory be able to complete the reaction in one further stage, using base amounts of chemicals.
Of course to do this pre-supposes you need to titrate. Also, depending on how much glycerol you use for the pre-treat, a 'normal' glycerol pre-treat is not going to neutralise oil that (say) titrates at 4.0
What I have found is that with my oil (titrating at 1.0 or thereabouts) just adding methanol to the glycerol will neutralise the FFA's and usually results in a 10/90 test of up to 20% conversion. The reason I only add methanol is that the residual chemicals left in the glycerol are biased in the favour of the catalyst. How do I know this? a Canadian guy on Infopop who used to advise a commercial producer ran some tests on enhancing glycerol with methanol and found it worked.
So, thats oil that titrates at 1.0 If your oil titrates at greater than that then to neutralise  the FFA's the glycerol will also need some KOH. Probably 1.0 gm/litre for every 1.0 titration greater than 1.0
A while ago someone on here was processing oil that titrated at over 10.0 He was getting a yield of 68%. After he tried the enhanced glyc wash his yield went up to 88%.
« Reply #8 on: June 20, 2015, 10:05:01 PM »
I always glyc wash and NEVER have to do a 3rd stage.
I use 15% and a 3g base but I do use ASM.
« Reply #9 on: June 20, 2015, 10:14:01 PM »
Yes Jim, but lets put this into perspective. After all you were one of the members that set me on the quest for min chemical usage. There is a world of difference between the mixing efficiency of the things that you and I use and an 'average processor'.
Is it 2x pumps and 2x 2stage eductors you use?
« Reply #10 on: June 20, 2015, 10:41:39 PM »
2 x 2stage eductors???????? now come on there, I've got 3 of the little buggers and a Squirrel.
Offline Bio-boy
« Reply #11 on: June 20, 2015, 11:24:40 PM »
Is there a way of working out the titration value of WVO without the need to titrate the WVO following the % conversion of stage 1 of a zero-titration reaction?
Following todays reaction I saw .7ml fallout from stage 1 using 16% methanol and 910g KOH. I'm sure there is but I'm not intelligent enough to work it out. I know its pretty easy to just titrate a sample but thats not the point. I'm curious about the correlation of the two types of calculations/reactions.
« Reply #12 on: June 20, 2015, 11:36:18 PM »
You don't have to worry about the acid value of stage two as it should neutral, you only need enough CATALYST to complete the conversion.
You could probably get away with 3g/ltr in stage two.
Offline Bio-boy
« Reply #13 on: June 21, 2015, 07:35:06 AM »
I appreciate the above but I was simply wondering if there is a method without titling your oil of working it out using the results of the 10/90 test following stage 1? I know it does't matter but I'm just curious.
« Reply #14 on: June 21, 2015, 07:58:28 AM »
What will a titration after stage 1 tell you ? As Jim says you will have neutralised the fatty acid so what you are left with is basically new oil. You just need to know how much is left to convert which is what the 10/90 tells you. Then use the base for whatever chem you use. After a 10/90 of the 2nd stage with a little experience you will get to know what base to use to get a good pass.
 By all means do a titration after stage 1 and let us know what it is. I haven't a clue, not even of any of my oil for the past 2 years.
 Been thinking about this and you might even get a negative reading after stage 1 due to the soap production screwing up any positive acid reading. Just like doing a soap test but you will be using the wrong Chema to get a reading.
« Last Edit: June 21, 2015, 08:28:19 AM by Manfred »
