Author Topic: Bio-Powered No-Titration Calculator  (Read 8935 times)
Re: Bio-Powered No-Titration Calculator
« Reply #15 on: June 21, 2015, 09:35:19 AM »
I have found that if I multiply the catalyst amount by 1.5 then I get a clear pas on the second stage. If I use the amount given by the calculation I always fail to get a clear pass.
« Reply #16 on: June 21, 2015, 10:02:16 AM »
I have tried to titrate after stage 1 many times (or as i now call it the enhanced glycerol pre-wash) and it can't be done as the oil is already alkaline. This is exactly what Manfred is saying, and lets face it, if after adding stage 1 chemicals the oil was still acidic there would be something seriously wrong.
Bio Boy, The base amount of catalyst you will need after stage 1 will vary depending on your processor/pump efficiency. From recent tests I have done using the tam 120/eductor I have found my base amount to be around the 6.7/6.8 gms KOH region. Whereas using a processor with a weak pump can give results of over 8 to 10 gms. These figures are without adjusting for KOH being only 90%.
So every processor has it's own base amount. When you calculate the amount of unreacted oil for your stage 2 chemicals you will get to know what the base amount is for your set-up from experiance.
The base amount was calculated years ago by tests using new oil and thats where the 5.0gms NaOH/7.0gmsKOH was first derived from.
Again from recent testing I have done, new oil still titrates, nor is it dry. Maybe thats why my testing figures are below base levels.
« Last Edit: June 21, 2015, 10:09:21 AM by dgs »
« Reply #17 on: June 21, 2015, 10:12:48 AM »
That seems a massive o/d of catalyst, doesn't it lead to making masses of soap?
« Reply #18 on: June 21, 2015, 10:51:28 AM »
The 1.5 x is only for stage 2 so a relatively small amount, apart from that all h2o will have been removed in stage 1, the only h2o present in the second stage will be that generated in the methoxide.
Offline Bio-boy
« Reply #19 on: June 21, 2015, 12:22:00 PM »
Sorry for any confusion guys. What I am trying to put across is if it is possible to utilise the results of the 10/90 test following the stage 1 process to identify the quality of the WVO. I don't mean titrating it following the 1st stage.
For example:
My most recent batch......
Stage 1 - 130L WVO 20.8L Methanol 910g KOH resulted in 2ml fallout (10/90 test)
Stage 2 - 5.2L methanol 182g KOH result clear pass 10/90 test.
So the total KOH used for the whole process is 1092g which if using the titration process rather than the no-titration process would equate to 1092/130=8.4
Therefore would I be right in thinking that the oil would have titrated at 8.4-7(base)=1.4
« Reply #20 on: June 21, 2015, 01:28:43 PM »
No, you're over analysing a rather simple process.
If you're getting a crystal clear final 10/90 why worry how or why it happens, just stick the bio in y'jam jar and enjoy the benefits.
« Reply #21 on: June 21, 2015, 02:59:47 PM »
I don't think so.  I only multiply by 1.5 if the fall out is below 1ml on a 10/90.
Offline Bio-boy
« Reply #22 on: June 21, 2015, 06:03:40 PM »
I'm just curious and wishing to develop my understanding further.
I see to have mastered the no-titration process. Clear 10/90 pass today, virtually no soap and only 3 washes required to achieve the perfect 50:50 test.
Can't wait to get my new plant operational. :)
« Reply #23 on: June 21, 2015, 10:20:44 PM »
I do 100 ltr batches, I use 6 grs naoh per ltr with 5 litres of meth in glycerol wash then 6 grs per ltr and 7ltr of meth on 1 st stage then around 3 for 2nd stage with 4lts of meth
Total of around 15grs per litre and 16% meth. Have recently been titrating at beginning of process and its between 20 and 25.
I can only assume that by doing in stages the amounts needed are less.
Offline Bio-boy
« Reply #24 on: June 21, 2015, 10:35:11 PM »
Your oil titrated at 20-25!!!  :o
« Reply #25 on: June 22, 2015, 09:47:58 AM »
Yes, some of us have to use oil that titrates at very high levels.
willbuild, the big problem with processing oil that titrates so high with a conventional base/base process is the loss of the FFA's to soap and water, which in your case will be 10 to 13%. However it's probably better (convenient) for you to do this than start to go down the route of acid esterification.
Was it you that increased your yield by some 20% doing the enhanced glycerol pre-wash?
It's a well known fact amongst more experianced brewers ( don't mean that to sound flippant) that the more reactions you do, the less chemicals you will use. Hence my min KOH usage experiments where I completed a batch with only 3.5gms/litre added KOH but had to use 7 stages to do it.
« Last Edit: June 22, 2015, 03:49:34 PM by dgs »
« Reply #26 on: June 22, 2015, 04:36:41 PM »
Yes it's improved by at least 15%, have done 4 batches using this method.
I have a batch of wvo settling that I know is high that am thinking of trying  caustic striping using the chart in one of your posts next week.
50% of the oil I collect is high but it use to be 75% so I'm heading in the right direction :)
